Cant authenticate Groove A-2Hn-32??
I have a mikrotik Groove A-2Hn-32 with a 14db panel antenna on it.
It has been working fine but suddenly I cant connect to it anymore.
It just shows extensive data loss in the logs and I cant authenticate.
So I reseted it did not help. updated the firmware nothing changed.
I dropped all security but still an authentication error.
tried to connect to it with a lot of different devices including another mikrotik still no connection.
Do you think its broken of are there some solutions to try?
Setup was is like this.
eth1 runs dhcp client to get access to manage it.
Vlan1 runs on eth1 and is bridged with wlan.
Vlan1 is connected to pfsense router which does the routing, firewall, nat, dhcp.
The groove does no routing, firewall, nat and dhcp.
I’ve changed the setup to standard settings but it doesn’t make a difference.
eth1 and wlan in a bridge. thats all for the factory settings.
i’ve tried routeros 6rc13 and 5.25
Just tested if I can make it connect to another accespoint in station mode this does work , weird.
Nobody knows a way to check what is causing the problem?
Post /export compact so everyone can see your config.
Ok it was just broken got a replacement
