Can't block a MAC WinBox connection using filters
Hi and Help,
Please forgive me if this belongs in the Newbie section or should go to Support rather than Forum (I am not eligable because I bought my router through a reseller of a reseller and it will take forever to get it escallated…) but if I am correct this appears to be a pretty serious “bug” that means anyone with LAN access can try to hack a MikroTik box and the only protection is a password which can’t be protected from a brute force attack.
Problem Description
I can not block a WinBox connection to a MAC address using filters.
Setup Description
Following my problems with a fairly involved firewall setup I simplified the configuration as much as possible. I reset my RB450G cleared the switch script, added an IP address to port 1 and added 2 very simple firewall rules which I think should block all connection attempts to the router configuration.
 MikroTik RouterOS 4.14 (c) 1999-2010       http://www.mikrotik.com/
[admin@MikroTik] > ip firewall filter export
# jan/02/1970 00:04:49 by RouterOS 4.14
# software id = 6KZV-LX84
add action=drop chain=input comment="" disabled=no
add action=drop chain=output comment="" disabled=no
I think with this setup I shouldn’t be able to access the configuration at all with any tool. If I try to connect using an IP address the filters work as I would expect and WinBox times out but I can still connect to the box if I use its MAC address.
I think this may be related to the similar DHCP issue in http://forum.mikrotik.com/viewtopic.php?uid=42736&f=2&t=14050&start=0 but this seems a lot more serious.
There may be a possible workaround using Mangle. The packets do go through Input and Output here but I can’t work out how to block them from Mangle (drop is not an option in mangle)
I am probably missing something but if I am not this a very big hole. It doesn’t seem to be addressed by firewall setups like the examples in the Wiki.
Ben
To allow mac winbox from specific ports configure interfaces in
“/tool mac-server mac-winbox” menu
Thanks, that is exactly what I need. Must have missed it in the documentation somewhere.
Ben
