can't block anything
hi
i read the manual for blocking .mp3 .avi
i di this do block mp3
[admin@MikroTik] ip web-proxy access> print
0 ;;; block telnet & spam e-mail relaying
dst-port=23-25 action=deny
1 url=“add url=”:\\.mp\[3g\]$" action=deny" action=deny
it did’t block
help plz
and what the line be to block .avi and mpg and mpeg
Have u configured the Web Proxy Properly.
Please Forward the configuration..I will help u out.
Also Make sure that u have mentioned the Web-proxy IP and Port in your web-browser.
Web browser
Tools->Internet Options->Connections->LAN Settings
Enable Proxy Server Settings, Write down ur Proxy IP ana Port which u have configured in MT Web Proxy.
ASHISH.
thanx for ur replay
i cofigured the web proxy with these rules
[admin@MikroTik] ip proxy> print
enabled: no
port: 8080
parent-proxy: 0.0.0.0:1
maximal-client-connecions: 1000
maximal-server-connectons: 1000
[admin@MikroTik] ip proxy> ..
[admin@MikroTik] ip> web-proxy
[admin@MikroTik] ip web-proxy> print
enabled: yes
src-address: 0.0.0.0
port: 3128
hostname: “proxy”
transparent-proxy: yes
parent-proxy: 0.0.0.0:0
cache-administrator: “webmaster”
max-object-size: 15096KiB
cache-drive: system
max-cache-size: unlimited
max-ram-cache-size: unlimited
status: running
reserved-for-cache: 13447168KiB
reserved-for-ram-cache: 2048KiB
firewall
chain=dstnat src-address=192.168.100.0/24 protocol=tcp dst-port=80 action=redirect to-ports=3128
i didn’t put any ip or port in web-browser for users
i think this is your problem:
enabled: no
:slight_smile:
Maybe i can help u. ur configuration in ip - web proxy is right. You must see this rule to block mp3 (watch the order):
  1. ip web proxy access> add url=“:\.mp[3g]$” action=deny
  2. ip web-proxy access> add src-address=x.x.x.x/x action=allow // specific ip u want to allow download mp3
and then, don’t forget to do this :
  • ex : 3128 - port of your proxy
    ip-firewall-filter
  • chain=input dst-address=“your ip” protocol=tcp dst-port=3128 (for example)
    action=drop // deny rely to your ip port 3128
ip firewall-nat
  • chain=dstnat in-interface=Internal protocol=tcp dst-port=80
    i wish u luck, :laughing:
you must ENABLE webproxy
ENABLE it for god sake …
sorry, I see you have enabled webproxy. but your rule looks incorrect, too many slashes. you should type it like in this example:
[admin@MikroTik] ip web-proxy access> add url=“:\.mp[3g]$” action=deny
ferry already explained everything
