Hi.
I have omnitik as a AP (ap bridge+wds). it seems to not forward IPX trafiic. Before it was two ovislink devices and everythink worked fine, now i changed one ovislink to omnitik and IPX doesnt work. I tried to sniff packets but it gives me nothing.
/system resource print
uptime: 3d7h29m42s
version: 5.26
free-memory: 49712KiB
total-memory: 62184KiB
cpu: MIPS 24Kc V7.4
cpu-count: 1
cpu-frequency: 400MHz
cpu-load: 6%
free-hdd-space: 90552KiB
total-hdd-space: 126976KiB
write-sect-since-reboot: 19679
write-sect-total: 20954
bad-blocks: 0.2%
architecture-name: mipsbe
board-name: RB OmniTIK U-5HnD
platform: MikroTik
Configuration:
interface wireless print
0 R name="wlan1" mtu=1500 mac-address=xx:xx:xx:xx:xx:xx arp=enabled interface-type=Atheros 11N mode=ap-bridge ssid="xxx" frequency=5180
band=5ghz-a channel-width=20mhz scan-list=default wireless-protocol=802.11 wds-mode=dynamic wds-default-bridge=bridge1 wds-ignore-ssid=no
bridge-mode=enabled default-authentication=no default-forwarding=no default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no
security-profile=default compression=no
/interface bridge print
0 R name="bridge1" mtu=1500 l2mtu=1600 arp=enabled mac-address=xx protocol-mode=none priority=0x8000 auto-mac=no
admin-mac=xx max-message-age=20s forward-delay=15s transmit-hold-count=6 ageing-time=5m
inter br por pri
Flags: X - disabled, I - inactive, D - dynamic
INTERFACE BRIDGE PRIORITY PATH-COST HORIZON
0 I ether2 bridge1 0x80 10 none
1 wlan1 bridge1 0x80 10 none
2 ether1 bridge1 0x80 10 none
3 I ether3 bridge1 0x80 10 none
4 I ether4 bridge1 0x80 10 none
5 I ether5 bridge1 0x80 10 none
6 D wds2 bridge1 0x80 74 none
7 D wds1
So as you see its pure bridge without any filters.
I have plenty of mikrotik devices and i always have default forward to “no”.
From MT wiki:
“default-forwarding (yes | no; Default: yes) This is the value of forwarding for clients that do not match any entry in the access-list”
Its my default config so i know what im saying.
