hi,
im use DSL modem and ROS,when i connect modem to PC working fine,but when i connect to router,my pc cant browse web and can use instant messager (like ICQ).
I was ask ISP ,the answer is they wont let me use router, in case to prevent many PC behide router.
is there anyway can rid of this restrict?
with best regard.
Who is your ISP?
you can change the MAC address of your public interface to the same as PC NIC. then you can use masquerading to hide your private network (I guess you already do that). and then also, maybe your ISP is checking TTL which you could change
Hi Normis ;
i saw you in many clips in tiktube site while i am reading about MT , you should change your photo here as it makes you look older . ![]()
here i need to ask you how can i check the TTL to know if there are users connecting more than a pc to the wireless connection i give and also how can i change the TTL value ?
with best regards .
Please stop hijacking topics. Is it really that hard to create a new one?
Hi ;
What do you mean by your reply ?
will wait your reply to update mine .
with best regards .
Your post had absolutely nothing to do with the original topic. For those of us active on the forum it makes it hard to keep up with things.
Hi ;
Thanks for your fast reply .
i sent it here as reply to Normis .
i think you and other forum managers get benefit from the facility " notify me when a reply is posted " to track the topics you wrote a reply in .
so it will be more easier to Normis to read my question about what he wrote , also i think he is now in USA for the MUM so he will be busy to read new topics in the forum .
also i think from the 8xx topics in the beginners basics , there is about 100 topic and the rest are relative to them .
any way i thought it will help more by replying in the same topic .
i will write a new topic now for the TTL case and i hope to read your comments as well .
thanks again and best regards .
Dear jwcn, what is your problem with ahmedsaffar76 first question?! he asked about TTL which is related with this topic, and BTW channingzou is a normal user not an ISP and he was asking for bypassing firewall filter which is set by his ISP. And I haven’t seen any useful input by you related with this topic. So please stop pulling others leg all the time.
Peace
Hi hulk ;
thanks for your post .
all members should act in friendly environment , today i get help from you and tomorrow i give you my help and so on .
will wait any feedback for the TTL case .
with best regards .
Dear ahmedsaffar76,
You are always welcome brother.
Salam n Peace
I never said he wasn’t welcome. No one is welcome to hijack topics. When I reviewed this again I realized his reply was on topic and I apologize.
Hi JWCN ;
we all are friends and partners and work in the same field under the name of MikroTik .
so each one should support the other that for the sake of MikroTik and their users .
with best regards .
Dear jwcn,
Never mind friend, I have just tried to be friendly here.
BTW jwcn can you please give us any kind of info about TTL and connection sharing matter.
Thanks n Peace
