gundam
December 28, 2012, 7:50am
1
hi, i’m beginner with mikrotik and i have some issue with my office mikrotik here that i need solution
like i said the subject, sometime we can’t go browsing but other connection is fine like yahoo messenger or outlook or other application that use internet until i reboot the mikrotik than we can browsing again but sometime we can’t again.
i really need help here, thanks
gundam
February 1, 2013, 4:23am
2
i hope someone can help me find the solution
gundam
February 4, 2013, 3:39am
4
no sir, we use static ip address, DNS, user Hotspot management bandwith, and some firewall + NAT
yesterday when the issue has come not only once reboot that can fix the problem, 2-3 times that we can use internet again normally.
i hope i know where is wrong so we can prevent this issue next come
What version of RouterOS ?
There were DNS bugs before 5.22
gundam
February 4, 2013, 10:39am
6
this is where i see the version right (system>packages)? 5.16
what kind DNS bugs?
Dobby
February 4, 2013, 10:59pm
7
Deleted because not related.
gundam
February 5, 2013, 5:43am
8
sorry about that, we know use RouterBoard 2011LS and before that we use RB750
so what should i do?
Dobby
February 6, 2013, 6:56pm
9
Also I would suggest upgrading to RouterOS 5.22 or newer, it sounds like the DNS bug
gundam
February 7, 2013, 2:50am
11
Dobby:
Hello again,
did you copy the configuration from the RB750 to the RB2011LS?
You restored a config from ANOTHER RB.
To copy a config between two RBs, you MUST use export/import.
Backups contain all interface mac addresses so restores should only be made on the SAME RB.
Seen in this thread: http://forum.mikrotik.com/t/rb1200-strange-or-normal/62939/1
Therefore I was asking for the RouterBoard you are using now !
yes i did and now we use RB2011LS
gundam
February 7, 2013, 2:51am
12
thanks, i try that and see how it going
