Can't change country
Hello, All Senior,
I’m new member. I bought mANTBox RB921GS 5HPacD 19s in Thailand last week. Current Version is 6.40.5. But I can’t change country. Please help me.
Thank all members.
In what procedure tried to change the setting?
webfig, winbox, or ssh?
I tried with webfig and winbox . But not support bro.
I
Devices sold in Thailand are locked to Thailand country. This is required by Thai law
How to unlock bro, Please help me .
Factory locked. You can not unlock it,but you can try to get unlocked international version from abroad. You should rather fulfill the local law otherwise the penalty may be applied to you.
I bought RB921 from Thailand. But I really use in Myanmar . And I don’t know this is locked devices. Do have another way to lock???
Return it to seller with request for refund or replacement because he had to inform you about the limitation. Maybe a special locker package can be applied to unlock the limitation, ask your distributor he should know if it is possible and if so, he will be able to provide such package to you.
Just a hint :slight_smile: - Netinstall, have a nice feature to un-check "keep old configuration " and “Apply default config” option :wink:
Thank for reply Bro,
Did anyone manage to unlock it? I have just got LOT of 30 pcs locked MikroTik’s devices. I am in Europe and I would like to unlock wireless. Anyone can help me with this???
