Can't communicate across bridges
Hi, after a bit of effort and some learning I have been able to get my new hAP ac3 router mostly up and running, but I’m a bit stuck on a step.
I have created 2 different bridges, one for wired devices and another one for the wireless ones. My idea is to allow unrestricted communication in the wired->wireless direction, and only some specific communication in the reverse direction. However, even though all the information I find implies that the communication across bridges is unrestricted by default, I can’t get devices across the two different bridges to communicate. Devices on both bridges can access the internet, and they can both also access the router IP on both networks (192.168.1.1 and 192.168.2.1).
My entire configuration is as follows:
# jan/13/2023 07:55:41 by RouterOS 7.5
# software id = 3NFC-4UGM
# model = RBD53iG-5HacD2HnD
# serial number = HDB08D5DAFZ
add name=local
add name=wlan-bridge
set [ find default-name=ether5 ] disabled=yes
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n channel-width=20/40mhz-Ce \
    country=spain disabled=no frequency=2452 mode=ap-bridge ssid=wlan-sc-2 \
    wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-n/ac country=spain disabled=no \
    frequency=auto mode=ap-bridge ssid=wlan-sc-5 wps-mode=disabled
/interface vlan
add interface=ether1 mtu=1488 name=vlan-pepephone vlan-id=20
add name=list-bridge
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
    supplicant-identity=MikroTik
add authentication-types=wpa2-psk mode=dynamic-keys name=guest \
/interface wireless
add disabled=no mac-address=1A:FD:74:DF:40:C2 master-interface=wlan1 name=\
    wlan-guest security-profile=guest ssid=lawifi wds-default-bridge=local \
    wps-mode=disabled
add name=dhcp_pool0 ranges=192.168.1.2-192.168.1.254
add name=dhcp_pool1 ranges=192.168.2.2-192.168.2.254
add address-pool=dhcp_pool0 interface=local name=dhcp1
add address-pool=dhcp_pool1 interface=wlan-bridge name=dhcp2
add bridge=local interface=ether2
add bridge=local interface=ether3
add bridge=local interface=ether4
add bridge=wlan-bridge interface=wlan1
add bridge=wlan-bridge interface=wlan2
set discover-interface-list=list-bridge
add interface=local list=list-bridge
add interface=wlan-bridge list=list-bridge
add address=192.168.1.1/24 interface=local network=192.168.1.0
add address=192.168.2.1/24 interface=wlan-bridge network=192.168.2.0
/ip dhcp-client
add interface=vlan-pepephone
/ip dhcp-server lease
add address=192.168.1.137 mac-address=1C:69:7A:A0:4E:3F server=dhcp1
add address=192.168.1.132 mac-address=D8:5E:D3:06:59:AB server=dhcp1
add address=192.168.1.0/24 dns-server=192.168.1.137 gateway=192.168.1.1
add address=192.168.2.0/24 dns-server=1.1.1.1,212.230.135.1 gateway=\
    192.168.2.1
add action=accept chain=input comment="accept established,related" \
add action=drop chain=input comment="drop invalid" connection-state=invalid
add action=accept chain=input comment="allow ICMP" in-interface=\
    vlan-pepephone protocol=icmp
add action=drop chain=input comment="block everything else" in-interface=\
    vlan-pepephone
add action=masquerade chain=srcnat out-interface=vlan-pepephone
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www port=8080
set ssh port=3242
set api disabled=yes
set winbox disabled=yes
set api-ssl disabled=yes
/ip ssh
set strong-crypto=yes
/system clock
set time-zone-name=Europe/Madrid
/tool bandwidth-server
set enabled=no
/tool mac-server
set allowed-interface-list=list-bridge
/tool mac-server mac-winbox
Thanks for your help
Same happens when connecting via WireGuard to the router. I can access the internet through that WireGuard link, and I can access the router IPs, but I can’t access any of the other connected devices.
You removed default firewall rules why?
I cannot spot anything in the configuration that would block the traffic between the subnets, so the reason can be either a bug in RouterOS 7.5 or the behaviour of the devices in the two subnets. How do you test that they can “communicate”? E.g. the default setting of Windows firewall blocks ping requests from other than own subnets.
To see what is really going on, use /tool sniffer quick - you can specify ip-address, ip-protocol and port parameters to sniff only the packets that really interest you, and see what is going on when you try to connect from a host in one subnet to a host in another. If everything was OK, you would see the request packet to enter the router via wlanX and then wlan-bridge, and leave it via local and then etherX; the response packet would take the same path but reverse. Seeing how far the request (and possibly response) gets will tell you where to look for the root cause of the issue.
I used the “reset configuration” action with the “no default configuration” option after some initial unsuccessful attempts to configure internet access with my provider.
By “communicate” I meant either ping, or accessing tcp or udp ports that should be open on the connected devices. There is no Windows machine, and while it’s true that they run their own firewall (iptables from ufw), I don’t see that the traffic should be blocked by them.
Thanks, this is useful, will dig a bit deeper with this.
Well, I finally found the issue. It wasn’t related to the router, which was working correctly, as I could see the packets being delivered to the devices in the other subnet.
The issue was that, because those devices had a VPN connection configured, they were routing the response packages across the VPN link, so they were lost. Adding a routing entry on those devices fixed the issue.
