Can't conn with WEBBOX on 192.168.0.150, 5 min before works!
Hi! i can run winbox OK, all system is good, just right now can’t connect anymore with LAN IP of my rb133c using webbox !
up to now all works, already connected, seeing graphs and immediately i can’t anymore!
what i have wrong? change some parameters? RUles router do not applied, port is 80 is always open..
I can’t give me a reason. can you help please? tks
I have had these porblems in the past aswell try logging in via MAC changing the IP address, sometimes the bridge can mess it up, basically renew your Ip address, and your bridge ports. That seems to work for me… I dont know why it does it sometimes but it does.. I dont have so many problem anymore though.. Good luck -Jordan
Hi i have solved, mistery i look here in WINBOX IP—>SERVICES it was that port WWW was disabled!!
i haven’t set disabled? i enable and immediately works… connected via LAN via browser
thanks
regardsMaurizio
