Can't connect after reboot
The quota to reboot on my RB2011UAS-2HnD is one time, any other reboot will make my router not able to online
i can find that the pppoe-out1 is connected, very little traffic will be seen, but my device just can’t connect to internet
the way to solve the problem is to restore or shutdown for a while(need many luck)
How can i solve this problem?
PS: don’t know why every i reboot it, the date and time will be reset…
thank you
This routerboard does not have battery backed RTC so after every reset clock is reset. Configure ntp client to synchronize time.
http://wiki.mikrotik.com/wiki/Manual:System/Time#SNTP_client
it work, thx :smiley:
