Can't connect between 2 subnet in 2 eth
Hi every one !
I have 2 ethernet with
  • eth1 ip= 192.168.0.1/24
  • eth2 ip =192.168.2.1/24
    and cable form 2 ethenet put in to 2 othe switch. How to do for them see itself. Sorry for bad english
If your router is gateway to both networks and firewall is not configured to drop connections between them, then it should work ok. Easy way to find out is disabling all Firewall/Filter rules, if it works, then some rule is blocking that traffic.
i has disabled all ruler but nothing change.
Are ports eth1 and eth2 in same bridge ?
Post your config here. Use export commnad:
export hide-sensitive
One more thing, consider proxy-arp .
