cvv
September 6, 2010, 7:28pm
1
Greetings
I have 2 LAN and 2 WAN interfaces with failover scripts. Everything works fine except for I can’t ping from LAN 1 (172.16.1.2) to LAN 2 (172.16.2.2). I can ping either network from the router, but can’t make it pass through.
[admin@MikroTik] /ip route> print
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S ;;; Default Route
0.0.0.0/0 pppoe-out1 1
1 S ;;; Backup Route
0.0.0.0/0 192.168.1.100 192.168.1.1 2
2 ADC 1.1.1.0/30 1.1.1.1 Loopback1 0
3 ADC 10.198.128.0/17 10.198.150.41 satnet 0
4 A S 92.255.86.24/32 cvv 1
5 A S ;;; Test Route
98.137.149.56/32 pppoe-out1 1
6 S ;;; Bogus loopback route for pppoe test
98.137.149.56/32 Loopback1 100
7 ADC 172.16.1.0/24 172.16.1.1 cvv 0
8 ADC 172.16.2.0/24 172.16.2.1 natasha 0
9 ADC 192.168.0.2/32 92.255.86.24 pppoe-out1 0
10 ADC 192.168.1.0/24 192.168.1.100 dlink-2540u 0
[admin@MikroTik] /ip address> print
# ADDRESS NETWORK BROADCAST INTERFACE
0 172.16.1.1/24 172.16.1.0 172.16.1.255 cvv
1 192.168.1.100/24 192.168.1.0 192.168.1.0 dlink-2540u
2 172.16.2.1/24 172.16.2.0 172.16.2.255 natasha
3 1.1.1.1/30 1.1.1.0 1.1.1.3 Loopback1
4 D 10.198.150.41/17 10.198.128.0 10.198.255.255 satnet
5 D 92.255.86.24/32 192.168.0.2 0.0.0.0 pppoe-out1
Letni
September 6, 2010, 7:47pm
2
When this has happened to me in the past I did not have the default gateway set right on one/both the clients.
On device 172.16.1.2 make sure the default gateway is 172.16.1.1
On device 172.16.2.2 make sure the default gateway is 172.16.2.1
-Louis
cvv
September 6, 2010, 8:07pm
3
Thanks for you reply.
Default getway on both devices is set as you’ve suggested
Letni
September 6, 2010, 8:11pm
4
From 172.16.1.2
ping 172.16.1.1. What the results?
ping 172.16.2.1. What are the results?
ping 172.16.2.2 What are the results?
What does a trace route show?
I am going to assume that you do not have any firewall rules that may be interfering since you did not include them before?
-Louis
fewi
September 6, 2010, 8:12pm
5
Post the output of “/ip firewall export”
On a side note, the IP address you’re using on the loopback interface has recently been assigned by the IANA.
cvv
September 6, 2010, 8:22pm
6
Letni:
From 172.16.1.2
-Louis
pinging 1.1 is OK, for it’s the router address for 1.2
pigning 2.1 or 2.2 fails
I have only set some NAT rules in firewall here they are:
[admin@MikroTik] > /ip firewall export
# sep/07/2010 00:17:58 by RouterOS 4.3
# software id = KV57-VKPA
/ip firewall address-list
add address=93.186.226.130 comment="" disabled=no list=vkontakte
add address=93.186.227.124 comment="" disabled=no list=vkontakte
add address=93.186.227.125 comment="" disabled=no list=vkontakte
add address=93.186.227.126 comment="" disabled=no list=vkontakte
add address=93.186.227.129 comment="" disabled=no list=vkontakte
add address=93.186.227.130 comment="" disabled=no list=vkontakte
add address=93.186.228.129 comment="" disabled=no list=vkontakte
add address=93.186.228.130 comment="" disabled=no list=vkontakte
add address=93.186.229.2 comment="" disabled=no list=vkontakte
add address=93.186.229.3 comment="" disabled=no list=vkontakte
add address=93.186.229.129 comment="" disabled=no list=vkontakte
add address=93.186.229.130 comment="" disabled=no list=vkontakte
add address=93.186.231.218 comment="" disabled=no list=vkontakte
add address=93.186.231.219 comment="" disabled=no list=vkontakte
add address=93.186.231.220 comment="" disabled=no list=vkontakte
add address=93.186.231.221 comment="" disabled=no list=vkontakte
add address=93.186.231.222 comment="" disabled=no list=vkontakte
add address=93.186.225.211 comment="" disabled=no list=vkontakte
add address=93.186.225.212 comment="" disabled=no list=vkontakte
add address=93.186.226.4 comment="" disabled=no list=vkontakte
add address=93.186.226.5 comment="" disabled=no list=vkontakte
add address=10.198.129.101 comment="" disabled=no list=blocked
add address=93.186.227.123 comment="" disabled=no list=vkontakte
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s tcp-close-wait-timeout=10s \
tcp-established-timeout=1d tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s \
tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=reject chain=forward comment="" disabled=yes dst-address-list=vkontakte protocol=tcp reject-with=\
icmp-admin-prohibited
add action=drop chain=forward comment="" disabled=yes src-address-list=blocked
/ip firewall mangle
add action=mark-routing chain=prerouting comment="" disabled=no dst-address=209.131.36.159 new-routing-mark=\
to-pppoe passthrough=no
add action=mark-connection chain=prerouting comment="p2p conn" disabled=no new-connection-mark=p2p_conn p2p=\
all-p2p passthrough=yes
add action=mark-packet chain=prerouting comment="p2p packet" connection-mark=p2p_conn disabled=no \
new-packet-mark=p2p passthrough=no
add action=mark-connection chain=prerouting comment="http conn" disabled=no dst-port=80 new-connection-mark=\
http_conn passthrough=yes protocol=tcp
add action=mark-packet chain=prerouting comment="http packet" connection-mark=http_conn disabled=no \
new-packet-mark=http passthrough=no
add action=mark-connection chain=prerouting comment="other conn" disabled=no new-connection-mark=other_conn \
passthrough=yes
add action=mark-packet chain=prerouting comment="other packet" connection-mark=other_conn disabled=no \
new-packet-mark=other passthrough=yes
add action=mark-connection chain=prerouting comment="smart conn" disabled=no dst-address=82.204.220.34 \
new-connection-mark=smart_conn passthrough=yes
add action=mark-connection chain=prerouting comment="smart conn" disabled=no dst-address=213.247.232.238 \
add action=mark-packet chain=prerouting comment="smart packet" connection-mark=smart_conn disabled=no \
new-packet-mark=smart passthrough=no
add action=masquerade chain=srcnat comment="" disabled=no out-interface=dlink-2540u
add action=src-nat chain=srcnat comment="" disabled=no out-interface=pppoe-out1 src-address=172.16.1.2 \
to-addresses=92.255.86.24
add action=dst-nat chain=dstnat comment="" disabled=no dst-address=92.255.86.24 in-interface=pppoe-out1 \
to-addresses=172.16.1.2
add action=masquerade chain=srcnat comment="For local satnet site" disabled=no out-interface=satnet
add action=masquerade chain=srcnat comment="" disabled=no out-interface=pppoe-out1 src-address=172.16.2.2
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
Letni
September 6, 2010, 8:43pm
7
Since you are not getting a response from 2.1 then your NAT rules are causing the issue.
If you disable them then it should work as expected OR
Option 2 is to add a couple more rules like
/ip firewall nat chain=srcnat action=accept src-address=172.16.1.0/24 dst-address=172.16.2.0/24
/ip firewall nat chain=srcnat action=accept src-address=172.16.2.0/24 dst-address=172.16.1.0/24
Make sure these are before your NAT rules.
-Louis
cvv
September 6, 2010, 8:54pm
8
Well, I’ve just disabled them all, doesn’t help
I’ve disabled all the previous rules and added yours, no change
cvv
September 9, 2010, 12:38am
9
Any other suggestions what to look at?
cvv
September 22, 2010, 8:58pm
10
I’ve found the solution, finally.
Silly me!
On windows-based computer 172.16.1.2 network mask was set occasionally to 255.255.0.0 (by default) instead of 255.255.255.0
That was the issue
Letni
September 22, 2010, 9:59pm
11
Traceroute results would have shown that sooner.
Glad you found your answer.
-Louis
