Cant connect to github.com from LAN
Please help to solve problem with github connection.
Windows pc on ether2, ping github.com, getting answers from mikrotik “destination host unreacheble”
Try to ping on mikrotik:
[admin@MikroTik] /tool> /ping count=5 google.com
  SEQ HOST                                     SIZE TTL TIME  STATUS
    0 64.233.161.113                             56  49 30ms
    1 64.233.161.113                             56  49 30ms
    2 64.233.161.113                             56  49 30ms
    3 64.233.161.113                             56  49 30ms
    4 64.233.161.113                             56  49 30ms
    sent=5 received=5 packet-loss=0% min-rtt=30ms avg-rtt=30ms max-rtt=30ms
[admin@MikroTik] /tool> /ping count=5 github.com
    0 192.30.253.112                                          timeout
    1 192.30.253.112                                          timeout
    2 192.168.88.1                               84  64 990ms host unreachable
    3 192.30.253.112                                          timeout
    4 192.30.253.112                                          timeout
    sent=5 received=0 packet-loss=100%
[admin@MikroTik] /tool> /ping count=5 interface=pppoe-out1 github.com
    0 192.30.253.113                             56  52 142ms
    1 192.30.253.113                             56  52 142ms
    2 192.30.253.113                             56  52 142ms
    3 192.30.253.113                             56  52 142ms
    4 192.30.253.113                             56  52 142ms
    sent=5 received=5 packet-loss=0% min-rtt=142ms avg-rtt=142ms max-rtt=142ms
Firewall only default rules. Nat masquerade and dst-nat torrent port.
/ip route export hide-sensitive
/ip firewall export hide-sensitive
Alternatively, paste the whole configuration from:
/export hide-sensitive
[admin@MikroTik] > /export hide-sensitive
# jul/06/2017 17:53:06 by RouterOS 6.39.1
# software id = R37B-JN1Q
add admin-mac=4C:5E:0C:5F:31:81 auto-mac=no fast-forward=no name=bridge-local
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] name=ether3-slave-local
set [ find default-name=ether4 ] name=ether4-slave-local
set [ find default-name=ether5 ] name=ether5-slave-local
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1-gateway keepalive-timeout=60 name=pppoe-out1 use-peer-dns=yes user=\
    v1616874
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode band=2ghz-b/g/n country=russia disabled=no distance=\
    indoors hw-protection-mode=rts-cts mode=ap-bridge ssid=dasnolojy tx-power=8 tx-power-mode=all-rates-fixed \
    wireless-protocol=802.11 wmm-support=enabled
/ip neighbor discovery
set ether1-gateway discover=no
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp authoritative=after-2sec-delay disabled=no interface=bridge-local name=default
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
/interface l2tp-server server
set caller-id-type=ip-address
add address=192.168.88.1/8 interface=ether2-master-local network=192.0.0.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid interface=ether1-gateway
/ip dhcp-server lease
add address=192.168.88.250 client-id=1:0:80:48:2d:df:3f mac-address=00:80:48:2D:DF:3F server=default
add address=192.0.0.0/8 gateway=192.168.88.1 netmask=8
add address=192.168.88.0/24 comment="default configuration" gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add action=accept chain=input comment="default configuration" protocol=icmp
add action=accept chain=input comment="default configuration" connection-state=established,related
add action=drop chain=input comment="default configuration" in-interface=ether1-gateway
add action=fasttrack-connection chain=forward comment="default configuration" connection-state=established,related
add action=accept chain=forward comment="default configuration" connection-state=established,related
add action=drop chain=forward comment="default configuration" connection-state=invalid
add action=drop chain=forward comment="default configuration" connection-nat-state=!dstnat connection-state=new in-interface=\
    ether1-gateway
add action=masquerade chain=srcnat comment="default configuration" out-interface=pppoe-out1
add action=netmap chain=dstnat comment=uTorrent dst-port=22699 in-interface=pppoe-out1 protocol=tcp to-addresses=192.168.88.250 \
    to-ports=22699
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
/system clock
set time-zone-name=Europe/Samara
/tool mac-server
add interface=ether2-master-local
add interface=ether3-slave-local
add interface=ether4-slave-local
add interface=ether5-slave-local
add
add interface=bridge-local
/tool mac-server mac-winbox
add
/tool sniffer
set filter-ip-protocol=icmp
You are using invalid IP addresses on your network, you cannot use 192.0.0.0/8 and expect to reach the Internet with consistency. Github happens to use 192.30.x.x for some of their servers, perhaps other IPs in different regions.
$ host github.com
github.com has address 192.30.255.112
github.com has address 192.30.255.113
In your configuration the router owns those IP addresses, if you login to your router and do a “ip route check 192.30.255.112” it will likely report it as being directly connected, as that is what your configuration says. Subnet masks matter, you need to change your settings to use valid IP subnets for private networks to avoid conflict.
Thank you very much
