Cant connect to internet
Hee hee,
I posted here a topic some time ago.
The problem then was that i could not locate mijn lokal ip.
After some puzzeling is solved the problem.
But now there is a new one :smiley:
When i look at my router logii see the following:
PPPoE initializing
PPPoE Dialing
PPPoE authenticated
PPPoE connected
Wlan1 connected
But then nothing happend.
I cant connect to the internet…
My computer says the follwing ( ihave windows 7):
Connectings problems with broad band modem
Plz restart the modem
I have done that like 20 time now but still no difference.
Does anyone know what the problem could be?
I am beginng to think is has something to do with my computer setting??
I set my IPv4 as followed:
P-Adress: 192.168.88.20
Subnetmasker: 255.255.255.0
StandardGateway: 192.168.88.2
DNS server 8.8.8.8/8.8.4.4
Dont now is that is causing the problem?
Thx for ur help!
Have DHCP configuration??
to center in you problem go to tools → ping do a ping from router to 8.8.8.8 for example
if not response, check this, PPPoE add default route checkbox on.
if yes, configure dhcp server, ip, dhcp server, dhcp setup.
