I just purchased a CRS310-8G+2S+IN and am unable to connect to my switch. WinBox doesn’t detect it when searching for neighbors and my computer is showing that the ethernet port is not connected. I’ve tried a factory reset by holding down the reset button when powering on and releasing when the power blue light flashes. After I did that however all port LED’s are now inactive. Am I missing anything here?
do you think you could supply the config of your router?
I have one that I use every day. I have right now, port 1 as my input. I am in the process of setting up a full 10gig network so I will move the input to sfp+1. how have you tried to access the switch for setup?
One quick question, Are you using the CRS310-8G+2S+IN as a router or as a switch? You do understand that the default address of the switch is 192.168.88.1?
I’m having similar issues with the exact same device. Did the OP get a resolution? This thing has seemed to have hard bricked and can’t be recovered with a reset.
Let’s start over. You have a CRS310-8G+2S+IN that you are unable to connect to. Is that correct?
you need to connect a laptop or computer set with thee IP of 192.168.88.10 (or anything other than 1) to any port on the CRS. If that port lights up you have a connection. if you get connectivity open a browser and enter http://192.168.88.1. you should be directed to the setup page of the CRS.
If this dosent work you might have to try Netinstall. If you truly need help just reply to this post.
Hello. I’m still having issues connecting to my switch. I’ve tried following the Netinstall instructions here but still can’t connect using Netinstall or winbox. Any port on the switch that I connect to is showing network cable unplugged on my ethernet adapter. I’ve tried using another switch inbetween but still can’t connect either. I’ve tried using IP’s of 192.168.88.2 and 192.168.88.10 and still can’t make a connection. When booting up the switch either all port lights are inactive or ports 1, 2, 3, 4, and 5 are showing both green and orange lights, ports 5 and 6 are inactive, and ports 7 and 8 are only showing green. Is there anything else I should be trying?
