Can't connect to router setting page with ethernet cable
Hi, I’m using hAPac^2 and after 3rd hardreboot all ethernet ports closed (except 22), so i can’t open setup page in the browser.
I’m using Minux Mint. I’ve done nmap 192.168.88.1. Can you please explain me this happened and how to fix this problem?
Use ethernet interface 2 to 5, not 1. Ethernet1 usually is defined as belonging to the WAN list, the others are bridged together and the bridge belongs to the LAN list.
WAN access is blocked by the firewall, as it is supposed to be the internet connection.
Unless you change the settings in the config … .
I’m not using 1st interface.
DK how, but everything fixed. Thanks for reply;)
