Cant Connect To Winbox
If im connected via my LAN I can log into winbox fine.
If I teather my iphone to my laptop where there is no free wifi and then connect via my L2TP VPN connection I can log into winbox but no data shows in any of the windows…i.e if I go onto DHCP Server → Leases nothing shows or in the firewall there are no rules in there.
If I connect to any wifi outside of my network thats not my iphone..i.e a free wifi hotspot then connect to my VPN everything works fine, I can log into winbox and see all the data.
Any ideas? Ive checked my drop rule and reset the counter to 0 so I can see if any traffic is being blocked and it isnt its still at 0.
Just strange that teathering my phone to my laptop then connecting to my VPN using my laptop that its not working but using any other internet source other than my phone it works fine.
Winbox isnt the only thing having issues, Using the same sinario above I try to log into my VMware ESX server using the vsphear app but it keeps timing out and saying the server took too long to respond and wont let me log again. Again this is using my phone as the internet teather and VPN Any other network with my vpn works fine. I can ping the ESX server and get a response just not log in :-/
Help :frowning:
Maybe is your problem your mobile provider, try another
Mobile provider can block some traffic on some ports
I can’t see that it is as I was only using it successfully the other week.
