Can't connect via WinBox, Telnet works: SOLVED
I have two MK routers set up with a WDS transparent bridge. All works fine on. The AP side can connect via WinBox, but not the station.
I can connect to the station using Telnet inside WinBox when connected to the AP.
My network:
Internet → AP (192.168.88.1) → WDS bridge over 2KM to Station (192.168.88.2) → Cisco home router
WinBox is enabled, however it won’t connect and the web interface won’t either.
When WinBox won’t connect, it says it can’t connect to 192.168.88.2 on port 80.
Any ideas why?
UPDATE I figured it out. I had no default route on the Station. Added default-route on 192.168.8.2 with dst-address of 0.0.0.0/0 with gateway 192.168.88.1
IP details of the AP:
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m \
    mac-cookie-timeout=3d
/ip neighbor discovery
set BigPond discover=no
add address=192.168.88.1/24 comment="default configuration" interface=\
    wds-bridge network=192.168.88.0
set allow-remote-requests=yes max-udp-packet-size=512 servers=\
    61.9.195.193,61.9.211.33
/ip dns static
add address=192.168.88.1 name=router
add action=masquerade chain=srcnat out-interface=BigPond
/ip proxy
set cache-on-disk=yes max-cache-size=3072000KiB parent-proxy=0.0.0.0
add distance=1 dst-address=192.168.89.0/24 gateway=192.168.88.3
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
Here is the config for the Station.
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes \
    disabled=no forward-delay=15s l2mtu=1598 max-message-age=20s mtu=1500 name=\
    wds-bridge priority=0x8000 protocol-mode=none transmit-hold-count=6
set 0 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1598 \
    mac-address=00:0C:42:E9:46:56 mtu=1500 name=ether1 speed=100Mbps
set [ find default=yes ] authentication-types="" eap-methods=passthrough \
    group-ciphers=aes-ccm group-key-update=5m interim-update=0s \
    management-protection=disabled management-protection-key="" mode=none name=\
    default radius-eap-accounting=no radius-mac-accounting=no \
    radius-mac-authentication=no radius-mac-caching=disabled radius-mac-format=\
    XX:XX:XX:XX:XX:XX radius-mac-mode=as-username static-algo-0=none \
    static-algo-1=none static-algo-2=none static-algo-3=none static-key-0="" \
    static-key-1="" static-key-2="" static-key-3="" static-sta-private-algo=\
    none static-sta-private-key="" static-transmit-key=key-0 \
    supplicant-identity=MikroTik tls-certificate=none tls-mode=no-certificates \
    unicast-ciphers=aes-ccm wpa-pre-shared-key="" wpa2-pre-shared-key=""
add authentication-types=wpa2-psk eap-methods="" group-ciphers=aes-ccm \
    group-key-update=5m interim-update=0s management-protection=allowed \
    management-protection-key="" mode=dynamic-keys name=wpa2 \
    supplicant-identity="" tls-certificate=none tls-mode=no-certificates \
    unicast-ciphers=aes-ccm wpa-pre-shared-key="" wpa2-pre-shared-key=\
    KEY
/interface wireless
set 0 adaptive-noise-immunity=none allow-sharedkey=no antenna-gain=0 area="" \
    arp=enabled band=2ghz-b/g basic-rates-a/g=6Mbps basic-rates-b=1Mbps \
    bridge-mode=enabled channel-width=20mhz compression=no country=\
    no_country_set default-ap-tx-limit=0 default-authentication=yes \
    default-client-tx-limit=0 default-forwarding=yes dfs-mode=none \
    disable-running-check=no disabled=no disconnect-timeout=3s distance=dynamic \
    frame-lifetime=0 frequency=2412 frequency-mode=manual-txpower \
    frequency-offset=0 hide-ssid=no ht-ampdu-priorities=0 ht-amsdu-limit=8192 \
    ht-amsdu-threshold=8192 ht-basic-mcs=\
    mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-guard-interval=any \
    ht-rxchains=0 ht-supported-mcs="mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mc\
    s-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-\
    18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23" ht-txchains=0 \
    hw-fragmentation-threshold=disabled hw-protection-mode=none \
    hw-protection-threshold=0 hw-retries=7 l2mtu=2290 mac-address=\
    00:0C:42:E9:46:57 max-station-count=2007 mode=station-wds mtu=1500 \
    multicast-helper=default name=wlan1 noise-floor-threshold=default \
    nv2-cell-radius=30 nv2-noise-floor-offset=default nv2-preshared-key="" \
    nv2-qos=default nv2-queue-count=2 nv2-security=disabled on-fail-retry-time=\
    100ms periodic-calibration=default periodic-calibration-interval=60 \
    preamble-mode=both proprietary-extensions=post-2.9.25 radio-name=\
    000C42E94657 rate-selection=advanced rate-set=default scan-list=default \
    security-profile=wpa2 ssid=Flame station-bridge-clone-mac=00:00:00:00:00:00 \
    supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps \
    supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 \
    tx-power-mode=default update-stats-interval=disabled wds-cost-range=50-150 \
    wds-default-bridge=wds-bridge wds-default-cost=100 wds-ignore-ssid=no \
    wds-mode=dynamic wireless-protocol=802.11 wmm-support=disabled
/interface wireless manual-tx-power-table
set wlan1 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbp\
    s:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:17,H\
    T20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,HT40-0:\
    17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-7:17"
/interface wireless nstreme
set wlan1 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=\
    3200 framer-policy=none
/ip hotspot profile
set [ find default=yes ] dns-name="" hotspot-address=0.0.0.0 html-directory=\
    hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=\
    cookie,http-chap name=default rate-limit="" smtp-server=0.0.0.0 \
    split-user-domain=no use-radius=no
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m name=default \
    shared-users=1 status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=3des \
    lifetime=30m name=default pfs-group=modp1024
/ppp profile
set 0 change-tcp-mss=yes name=default only-one=default use-compression=default \
    use-encryption=default use-mpls=default use-vj-compression=default
set 1 change-tcp-mss=yes name=default-encryption only-one=default \
    use-compression=default use-encryption=yes use-mpls=default \
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 \
    red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set 5 kind=none name=only-hardware-queue
set 6 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 7 kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes disabled=no \
    ignore-as-path-len=no name=default out-filter="" redistribute-connected=no \
    redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no \
    redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never in-filter=ospf-in \
    metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=auto \
    metric-rip=20 metric-static=20 name=default out-filter=ospf-out \
    redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no \
    redistribute-rip=no redistribute-static=no router-id=0.0.0.0
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=\
    backbone type=default
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0 authentication-password="" \
    authentication-protocol=MD5 encryption-password="" encryption-protocol=DES \
    name=public read-access=yes security=none write-access=no
/system logging action
set 0 memory-lines=100 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=log disk-lines-per-file=100 \
    disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=no name=remote remote-port=514 src-address=0.0.0.0 \
    syslog-facility=daemon syslog-severity=auto target=remote
/user group
set read name=read policy="local,telnet,ssh,reboot,read,test,winbox,password,web\
    ,sniff,sensitive,api,!ftp,!write,!policy" skin=default
set write name=write policy="local,telnet,ssh,reboot,read,write,test,winbox,pass\
    word,web,sniff,sensitive,api,!ftp,!policy" skin=default
set full name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,wi\
    nbox,password,web,sniff,sensitive,api" skin=default
add bridge=wds-bridge disabled=no edge=auto external-fdb=auto horizon=none \
    interface=ether1 path-cost=10 point-to-point=auto priority=0x80
    interface=wlan1 path-cost=10 point-to-point=auto priority=0x80
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=default-encryption \
    enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=\
    default enabled=no keepalive-timeout=60 mac-address=FE:72:08:F9:2F:83 \
    max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption enabled=\
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=\
    default enabled=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=\
    disabled port=443 verify-client-certificate=no
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=\
    00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 \
    frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 \
    multiple-channels=no only-headers=no receive-errors=no streaming-enabled=no \
    streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=192.168.88.2/24 disabled=no interface=wds-bridge network=\
    192.168.88.0
/ip dhcp-server config
set store-leases-disk=5m
set allow-remote-requests=no cache-max-ttl=1w cache-size=2048KiB \
    max-udp-packet-size=4096 servers=""
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
    tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=\
    10s tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s \
    tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s \
    udp-stream-timeout=3m udp-timeout=10s
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
/ip hotspot service-port
set ether1 disabled=no
set wlan1 disabled=yes
set wds-bridge disabled=no
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 \
    cache-on-disk=no enabled=no max-cache-size=unlimited \
    max-client-connections=600 max-fresh-time=3d max-server-connections=600 \
    parent-proxy=0.0.0.0 parent-proxy-port=0 port=8080 serialize-connections=no \
    src-address=0.0.0.0
/ip service
set telnet address="" disabled=no port=23
set ftp address="" disabled=no port=21
set www address="" disabled=no port=80
set ssh address="" disabled=no port=22
set www-ssl address="" certificate=none disabled=yes port=443
set api address="" disabled=yes port=8728
set winbox address="" disabled=no port=8291
/ip smb
set allow-guests=yes comment=MikrotikSMB domain=MSHOME enabled=no interfaces=\
    all
/ip smb shares
set [ find default=yes ] comment="default share" directory=/pub disabled=no \
    max-sessions=10 name=pub
/ip smb users
set [ find default=yes ] disabled=no name=guest password="" read-only=yes
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no inactive-flow-timeout=\
    15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
set [ find default=yes ] disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no \
    lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 \
    use-explicit-null=no
/port firmware
set directory=firmware ignore-directip-modem=no
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set ether1 queue=only-hardware-queue
set wlan1 queue=wireless-default
/radius incoming
set accept=no port=3799
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s \
    multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m \
    gateway-selection=no-gateway origination-interval=5s preferred-gateway=\
    0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 \
    metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no \
    redistribute-connected=no redistribute-ospf=no redistribute-static=no \
    routing-table=main timeout-timer=3m update-timer=30s
/snmp
set contact="" enabled=no engine-id="" location="" trap-generators="" \
    trap-target="" trap-version=1
/system clock
set time-zone-name=manual
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=\
    "jan/01/1970 00:00:00" time-zone=+00:00
/system identity
set name=MikroTik
/system logging
set 0 action=memory disabled=no prefix="" topics=info
set 1 action=memory disabled=no prefix="" topics=error
set 2 action=memory disabled=no prefix="" topics=warning
set 3 action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=no mode=broadcast primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
/system routerboard settings
set boot-device=nand-if-fail-then-ethernet boot-protocol=bootp cpu-frequency=\
    600MHz force-backup-booter=no silent-boot=no
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=\
    0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=\
    none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=100
/tool e-mail
set address=0.0.0.0 from=<> password="" port=25 starttls=no user=""
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no secret=""
/tool sniffer
set file-limit=1000KiB file-name="" filter-ip-address="" filter-ip-protocol="" \
    filter-mac-address="" filter-mac-protocol="" filter-port="" filter-stream=\
    yes interface=all memory-limit=100KiB memory-scroll=yes only-headers=no \
    streaming-enabled=no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-scale=10 test-id=0
/user aaa
set accounting=yes default-group=read exclude-groups="" interim-update=0s \
    use-radius=no
