Can't connect via Winbox
Hi
I can ssh/telnet/webfig to my MT. However I cannot winbox to it anymore.
I’ve tried ip services winbox disable/enable and still no luck.
Any suggestions?
Regards
Tenacious
Have you unintentionally blocked access to port 8291 on the input chain?
No, no configuration changes were made
you can find where winbox places dll’s in your user profile and remove those. Also, make sure you are using IP address instead of mac address in winbox.
If service is enabled and not blocked by firewall and PC have no weird restrictions set to inbox loader, then there should be no other problems.
Eventually SSH wouldn’t work either, I telnet’d in and rebooted the MT.
Which restored winbox and ssh connectivity.
I would of rebooted the MT earlier, but I don’t the client would of been too pleased :slight_smile:
Thanks for the help guys
