Hi all.
On some CPE SXT’s I have strange problem after some time. I add frequencies manually to scan-list (ex. 5180,5200,5220,5240,5260…).
They work normally and after some time they disconnect and I can’t ‘see’ AP on scan any more. If I remove all frequencies and add only AP frequency I can connect and if I turn back all frequencies then everything is as it was. Problem is that I must came to my customer and do this. This happens on all versions I have. From 5.11 to 6.7.
Interesting thing is that this happens only on few CPE’s and reboot doesn’t help. I must change scan-list, connect, return back as it was and then it works. Al CPE’s have same config.
Anyone have similar problem?
Thx
