can't do subnetting......
Hi friends
I am facing some issues while doing subnetting. I done subnetting for 10.10.10.0 series.
Address Network Interface
1)10.10.10.1/27 10.10.10.0 ether2
2)10.10.10.33/29 10.10.10.32 ether2
3)10.10.10.41/30 10.10.10.40* ether2
4)10.10.10.45/29 10.10.10.40* ether2
For 3 and 4 it showing the same network address as mentioned above. Please help me to sort out this problem.
Regards
Sareesh
Hello again sareeshkg,
Do we talking about the RouterBoard 450G from the last thread?
Would you please draw a small network map that everybody is able to
understand what and why you want to do or plain set up, by using this method you were talking about!
Or could you come more near to the point you want to go.
In normal terms and conditions you will be able to set up VALNs in your network and each of this VLANs can have their own
subnet with an own IP range! And then the router is able to do for what he was produced for, routing.
