Some times ago I configured a CRS328 that used 3 DSL lines to connect to the Internet.
I followed [1] to edit the different rules.
Months later, I changed my config when this CRS328 became connected to the Internet through a single FTTH line.
Doing so, I mostly disabled existing rules.
Now, this CRS328 has a second single FTTH line.
So I tried to edit and enable some previously disabled rules to adapt to this new requirement, using WebFig.
Specifically, using WebFig, I tried to change a rule from:
/ip firewall mangle add chain=prerouting action=mark-connection \
new-connection-mark=1st_conn per-connection-classifier=src-address-and-port:3/0
to
new-connection-mark=1st_conn per-connection-classifier=src-address-and-port:2/0
To my surprise, old settings remained, no matter how I proceed clicking over Apply or OK buttons.
I’ve not tried yet, to work around the issue using either CLI or creating new rules from scratch instead.
Can someone take a look at this ?
My RouterOS version was 6.44.3.
I observed the same after an upgrade to 6.48.5.
Best regards
[1] https://wiki.mikrotik.com/wiki/Manual:PCC
