can't establish connection
here is the situation: I’m using
the first point:
1 RB 133 as AP
1 Compex WLM54AG minipci card
1 Antenna (Rootena) Pac wireless 19 dbi
Wireless mode:AP Bridge
the second point:
1 RB 133 c as Station
Wireless mode:Station
the problem is so: I can’t get connection between the 2 points, if i scan from the station, I can see the access point, link strength: -78, but still no connection, I use the b antenna (have used a antenna without success), TX power default, Frequency country :Algeria, Frequency:5640 Mhz.Noise to Floor value is= -115 db
Thank a lot,
