cant find wireless interface
just installed routeros v 5.20 on acer laptop and connected to by winbox but i cant find the wireless card in interface as i want to make the lan card my WAN and the wireless card my WAN
First … ROS 5.20 is SO OLD … try to use 6.40.4 but IMHO it has small chance to work as ROS is not general purpose system which accepts any kind of WiFi cards. … even it is Linux under the hood. You need to install VMWare or KVM first and then ROS on it.
thank you for your reply
so i can install ROS on VM and still can controll the network through it??
Yes.
Look here: https://wiki.mikrotik.com/wiki/Manual:CHR
