Can't forward ports for minecraft server
Hi, i’m trying to forward 25565 port for minecraft. It’s just doesn’t work. I have default filter rules and masquerade.
the full config not snippets is better ( minus router serial number and any public wanip information )
why are you port forwarding to the IP address of the LAN subnet 192.168.88.1 vice the IP address of the server 192.168.88.XY
I searched for guides on internet and did what they said.
So I need to send my config file or what?
Not interested, if all your doing is copying shit without an iota of attempt to learn.
My best guess: you are trying to forward to your router (I assume 192.168.88.1 is your router address?).
Can you connect to 192.168.88.1:25565 if you are on your LAN?
