Can't get 1Gbps on CRS125-24G-1S-2HnD
Hi!
Please help me to determine why my router doesn’t set 1Gbps/Full Duplex on LAN ports after auto negotiation?
All PCs connected to router have gigabyte ethernet controller and speed/duplex set to auto negotiation.
There is my config:
[admin@MikroTik] > /export hide
# nov/22/2018 12:29:44 by RouterOS 6.43.4
# software id = IQIU-GJ8M
# model = CRS125-24G-1S-2HnD
# serial number = 523A05606C82
add admin-mac=E4:8D:8C:42:80:DF auto-mac=no name=bridge-local
set [ find default-name=ether1 ] name=ether1-gateway speed=100Mbps
set [ find default-name=ether2 ] name=ether2-master-local speed=100Mbps
set [ find default-name=ether3 ] name=ether3-slave-local speed=100Mbps
set [ find default-name=ether4 ] name=ether4-slave-local speed=100Mbps
set [ find default-name=ether5 ] name=ether5-slave-local speed=100Mbps
set [ find default-name=ether6 ] name=ether6-slave-local speed=100Mbps
set [ find default-name=ether7 ] name=ether7-slave-local speed=100Mbps
set [ find default-name=ether8 ] name=ether8-slave-local speed=100Mbps
set [ find default-name=ether9 ] name=ether9-slave-local speed=100Mbps
set [ find default-name=ether10 ] name=ether10-slave-local speed=100Mbps
set [ find default-name=ether11 ] name=ether11-slave-local
set [ find default-name=ether12 ] name=ether12-slave-local speed=100Mbps
set [ find default-name=ether13 ] name=ether13-slave-local
set [ find default-name=ether14 ] name=ether14-slave-local speed=100Mbps
set [ find default-name=ether15 ] name=ether15-slave-local speed=100Mbps
set [ find default-name=ether16 ] name=ether16-slave-local speed=100Mbps
set [ find default-name=ether17 ] name=ether17-slave-local speed=100Mbps
set [ find default-name=ether18 ] name=ether18-slave-local speed=100Mbps
set [ find default-name=ether19 ] name=ether19-slave-local speed=100Mbps
set [ find default-name=ether20 ] name=ether20-slave-local speed=100Mbps
set [ find default-name=ether21 ] name=ether21-slave-local speed=100Mbps
set [ find default-name=ether22 ] name=ether22-slave-local speed=100Mbps
set [ find default-name=ether23 ] name=ether23-slave-local speed=100Mbps
set [ find default-name=ether24 ] name=ether24-slave-local speed=100Mbps
set [ find default-name=sfp1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=sfp1-slave-local
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
add authentication-types=wpa-psk,wpa2-psk management-protection=allowed mode=dynamic-keys name=*** supplicant-identity=\
    MikroTik
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce disabled=no distance=indoors frequency=auto mode=\
    ap-bridge scan-list=default,5200-5300,5200-5300 security-profile=*** ssid=***-1 wireless-protocol=802.11
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
add name=dhcp ranges=192.168.88.2-192.168.88.200
add name=openvpn-pool ranges=172.30.0.2-172.30.0.200
add address-pool=dhcp authoritative=after-2sec-delay disabled=no interface=bridge-local name=default
/ppp profile
add local-address=172.30.0.1 name=openvpn remote-address=openvpn-pool
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
add bridge=bridge-local interface=ether3-slave-local
add bridge=bridge-local interface=ether4-slave-local
add bridge=bridge-local interface=ether5-slave-local
add bridge=bridge-local interface=ether6-slave-local
add bridge=bridge-local interface=ether7-slave-local
add bridge=bridge-local interface=ether8-slave-local
add bridge=bridge-local interface=ether9-slave-local
add bridge=bridge-local interface=ether10-slave-local
add bridge=bridge-local interface=ether11-slave-local
add bridge=bridge-local interface=ether12-slave-local
add bridge=bridge-local interface=ether13-slave-local
add bridge=bridge-local interface=ether14-slave-local
add bridge=bridge-local interface=ether15-slave-local
add bridge=bridge-local interface=ether16-slave-local
add bridge=bridge-local interface=ether17-slave-local
add bridge=bridge-local interface=ether18-slave-local
add bridge=bridge-local interface=ether19-slave-local
add bridge=bridge-local interface=ether20-slave-local
add bridge=bridge-local interface=ether21-slave-local
add bridge=bridge-local interface=ether22-slave-local
add bridge=bridge-local interface=ether23-slave-local
add bridge=bridge-local interface=ether24-slave-local
add bridge=bridge-local interface=sfp1-slave-local
set discover-interface-list=discover
add interface=wlan1 list=discover
add interface=ether2-master-local list=discover
add interface=ether3-slave-local list=discover
add interface=ether4-slave-local list=discover
add interface=ether5-slave-local list=discover
add interface=ether6-slave-local list=discover
add interface=ether7-slave-local list=discover
add interface=ether8-slave-local list=discover
add interface=ether9-slave-local list=discover
add interface=ether10-slave-local list=discover
add interface=ether11-slave-local list=discover
add interface=ether12-slave-local list=discover
add interface=ether13-slave-local list=discover
add interface=ether14-slave-local list=discover
add interface=ether15-slave-local list=discover
add interface=ether16-slave-local list=discover
add interface=ether17-slave-local list=discover
add interface=ether18-slave-local list=discover
add interface=ether19-slave-local list=discover
add interface=ether20-slave-local list=discover
add interface=ether21-slave-local list=discover
add interface=ether22-slave-local list=discover
add interface=ether23-slave-local list=discover
add interface=ether24-slave-local list=discover
add interface=sfp1-slave-local list=discover
add interface=bridge-local list=discover
add interface=ether2-master-local list=mactel
add interface=ether3-slave-local list=mactel
add interface=ether2-master-local list=mac-winbox
add interface=ether4-slave-local list=mactel
add interface=ether3-slave-local list=mac-winbox
add interface=ether5-slave-local list=mactel
add interface=ether4-slave-local list=mac-winbox
add interface=ether6-slave-local list=mactel
add interface=ether5-slave-local list=mac-winbox
add interface=ether7-slave-local list=mactel
add interface=ether6-slave-local list=mac-winbox
add interface=ether8-slave-local list=mactel
add interface=ether7-slave-local list=mac-winbox
add interface=ether9-slave-local list=mactel
add interface=ether8-slave-local list=mac-winbox
add interface=ether10-slave-local list=mactel
add interface=ether9-slave-local list=mac-winbox
add interface=ether11-slave-local list=mactel
add interface=ether10-slave-local list=mac-winbox
add interface=ether12-slave-local list=mactel
add interface=ether11-slave-local list=mac-winbox
add interface=ether13-slave-local list=mactel
add interface=ether14-slave-local list=mactel
add interface=ether12-slave-local list=mac-winbox
add interface=ether15-slave-local list=mactel
add interface=ether13-slave-local list=mac-winbox
add interface=ether16-slave-local list=mactel
add interface=ether14-slave-local list=mac-winbox
add interface=ether17-slave-local list=mactel
add interface=ether15-slave-local list=mac-winbox
add interface=ether18-slave-local list=mactel
add interface=ether16-slave-local list=mac-winbox
add interface=ether19-slave-local list=mactel
add interface=ether20-slave-local list=mactel
add interface=ether21-slave-local list=mactel
add interface=ether22-slave-local list=mactel
add interface=ether23-slave-local list=mactel
add interface=ether17-slave-local list=mac-winbox
add interface=ether24-slave-local list=mactel
add interface=ether18-slave-local list=mac-winbox
add interface=sfp1-slave-local list=mactel
add interface=ether19-slave-local list=mac-winbox
add interface=wlan1 list=mactel
add interface=ether20-slave-local list=mac-winbox
add interface=bridge-local list=mactel
add interface=ether21-slave-local list=mac-winbox
add interface=ether22-slave-local list=mac-winbox
add interface=ether23-slave-local list=mac-winbox
add interface=ether24-slave-local list=mac-winbox
add interface=sfp1-slave-local list=mac-winbox
add interface=wlan1 list=mac-winbox
add interface=bridge-local list=mac-winbox
/interface ovpn-server server
set certificate=cert_12 cipher=blowfish128,aes128,aes192,aes256 default-profile=openvpn enabled=yes require-client-certificate=\
    yes
/interface sstp-server server
set authentication=mschap2 enabled=yes
add address=192.168.88.1/24 comment="default configuration" interface=ether2-master-local network=192.168.88.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=no interface=ether1-gateway
/ip dhcp-server lease
add address=192.168.88.249 mac-address=0C:9D:92:BF:FC:A0
add address=192.168.88.0/24 comment="default configuration" gateway=192.168.88.1
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.88.1 name=router
add action=fasttrack-connection chain=forward comment="default configuration" connection-state=established,related
add action=drop chain=input comment="default configuration" disabled=yes in-interface=ether1-gateway log=yes log-prefix=\
    icmp_input_ protocol=icmp
add action=drop chain=input dst-port=22 in-interface=ether1-gateway log=yes protocol=tcp
add action=drop chain=input dst-port=80 in-interface=ether1-gateway log=yes protocol=tcp
add action=drop chain=input dst-port=8291 in-interface=ether1-gateway in-interface-list=all log=yes protocol=tcp
add action=drop chain=input dst-port=8728,8729 in-interface=ether1-gateway log=yes protocol=tcp
add action=accept chain=input dst-port=1194 in-interface=ether1-gateway protocol=tcp
add action=accept chain=forward comment="default configuration" connection-state=established,related
add action=drop chain=forward comment="default configuration" connection-nat-state=!dstnat connection-state=new in-interface=\
    ether1-gateway
add action=masquerade chain=srcnat comment="default configuration" out-interface=ether1-gateway
add action=dst-nat chain=dstnat comment="Temp connection for UIS support" disabled=yes dst-port=28475 in-interface=ether1-gateway \
    log=yes log-prefix=grandstream protocol=tcp to-addresses=192.168.88.35 to-ports=80
/ip service
set telnet disabled=yes
set ftp disabled=yes
/lcd interface pages
set 0 interfaces=wlan1
/ppp secret
add name=*** profile=openvpn service=ovpn
/system clock
set time-zone-name=Europe/Moscow
/system logging
add topics=ovpn,debug
/system routerboard settings
set silent-boot=no
/tool bandwidth-server
set authenticate=no
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
/tool romon port
add
What happens if you remove auto negotiation, can you force Gb?
I think you Are forcing 100mbs on each interface…
No-one’s forcing anything. This is just what you WOULD get, IF you were to turn off auto-negotiation, which you haven’t.
If it bothers you that much, then set the ports to the default speed (it seems to vary based on model and software version).
Yep, this is default value now, even for Gb capable switch (?)
[admin@Mancave-Switch] > /interface ethernet export
# nov/22/2018 14:20:55 by RouterOS 6.43.4
# software id = DV88-GETP
# serial number = REMOVED
set [ find default-name=ether1 ] speed=100Mbps
set [ find default-name=ether2 ] speed=100Mbps
Nope, when you reset configuration with ROS 6.43, export won’t show the “speed=100Mbps” or whatever value. The reason being that export will only show parameters that are different than default.
So why all the sudden everybody sees this infamous “speed=100Mbps”? Because default changed from 100Mbps to 1Gbps with ROS 6.43 but actual settings don’t change with ROS upgrade. So everybody who started with ROS <= 6.42 will see it now (but it wasn’t displayed previously as it was default). If somebody changed this parameter to 1Gbps with previous versions, then export showed it but doesn’t show it after upgrade to >=6.43.
The actual value, as displayed by print command, doesn’t change with change of ROS version.
I’m not sure where you’d find this in the CLI, but in Winbox, the Status tab shows the details of the auto negotiate status. Take a look at that and post a screenshot back.
The OP hasn’t bothered even to logon to the foum since between posts #3 and #4.
Tells you a lot doesn’t it?
