i have a mikrotik 450G (and tried 750) with VLAN 1 on port 2, and an IP allocated to that vlan1.
then i connect a switch (namely ‘planet’), i setup that switch to use 802.1Q with vlan 1 on the port that the Mikrotik connects to.
but when i use the mikrotik and ping the ip of the switch strangly:
a) i cannot ping the switch unless i put the switch into port based vlan1.
b) i cannot sniff any packets going out on vlan 1 yet i can see traffic on that vlan
ive replaced the planet with a cisco 3500xl and the same thing happens… ive also replaced the mikrotik connection to the planet with a pc and it works fine…
have i missed any steps to configuring 802.1Q on the mikrotik?
a) dot1q is working fine for me between an RB1000 and a 3560G. Post the output of “/int eth pri det”, “/int vl pri det”, “/ip add pri det” from the RouterOS device, and “sh vlan” and “sh run int fa0/x” (substitute for uplink port) on the Cisco side.
b) Wild guess: vlan 1 is special on Cisco (it’s the default native vlan). The native on a port has all dot1 tags stripped when forwarded out the port. Unless you’ve set the native vlan on the port to be something else, you’re sending out a packet without a dot1q tag to a device that expects a dot1q tag to match traffic to its vlan 1 interface. Since there’s no tag, traffic doesn’t go to the vlan interface but to the ethernet interface instead as that receives all non-dot1 traffic. Either use vlan 2, or set the native vlan on the Cisco port to 2 (or something else).
i found that the planet wasn’t working with the mikrotik (most likely planet fault) with tagged setting so i set port to untagged and all is well with no vlans for management.
