When I plug my laptop into eth2 on CAP, it gets an IP on the VLAN99. Still no IP for the CAP.
From the DHCP server RB4011
/ip/dhcp-server/lease> print
Flags: D - DYNAMIC
Columns: ADDRESS, MAC-ADDRESS, HOST-NAME, SERVER, STATUS, LAST-SEEN
15 D 192.168.99.98 78:9A:18:10:9E:7A MikroTik MGMT offered 0s
16 D 192.168.99.99 00:2B:67:C9:3F:07 LenovoP53s MGMT bound 2m44s
RB4011 config:
# 2023-11-24 19:58:44 by RouterOS 7.13beta2
# software id = L2GF-7Z2L
# model = RB4011iGS+
# serial number = ***
add admin-mac=*** auto-mac=no comment=defconf name=bridge \
port-cost-mode=short protocol-mode=mstp vlan-filtering=yes
set [ find default-name=ether1 ] comment=WAN name=ether1-WAN
set [ find default-name=ether2 ] comment=LAN name=ether2-access
set [ find default-name=sfp-sfpplus1 ] loop-protect=on
/interface vlan
add comment="VLAN for Mgmt" interface=bridge name=MGMT vlan-id=99
add comment=Hypervisor interface=bridge name=VLAN10 vlan-id=10
add comment=Servers interface=bridge name=VLAN20 vlan-id=20
add comment=Data interface=bridge name=VLAN30 vlan-id=30
add comment=Work interface=bridge name=VLAN50 vlan-id=50
add comment="Untrusted LAN" interface=bridge name=VLAN60 vlan-id=60
add interface=bridge name=VLAN100-LAB vlan-id=100
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=Work
add name=VLAN
add name=Winbox
add name=Wifi
/interface lte apn
/interface wifi channel
add disabled=no name="5 Ghz AX"
add band=2ghz-ax disabled=no name="2.5 Ghz AX"
add band=5ghz-a disabled=no name="5Ghz A"
add band=5ghz-n disabled=no name="5Hgz A/N"
add band=5ghz-ac disabled=no name="5Ghz A/C"
add band=2ghz-g disabled=no name="2Ghz G"
add band=2ghz-n disabled=no name="2Ghz N"
/interface wifi datapath
add bridge=bridge disabled=no name=Trusted vlan-id=30
add bridge=bridge disabled=no name=Guest vlan-id=60
add bridge=bridge disabled=no name=IoT vlan-id=60
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no encryption=\
ccmp,ccmp-256 name=Trusted wps=disable
ccmp,ccmp-256 name=Guest wps=disable
ccmp,ccmp-256 name=IoT wps=disable
/interface wifi configuration
add channel="5 Ghz AX" country="United States" datapath=Trusted disabled=no \
manager=capsman mode=ap name=Trusted security=Trusted ssid=Maranatha
add channel="2.5 Ghz AX" country="United States" datapath=Guest disabled=no \
manager=capsman mode=ap name=Guest security=Guest ssid=GMaranatha
add channel="2.5 Ghz AX" country="United States" datapath=IoT disabled=no \
manager=capsman mode=ap name=IoT security=IoT ssid=IMaranatha
/ip ipsec policy group
add name=vpn
/ip ipsec profile
add dh-group=modp1024 enc-algorithm=aes-256 hash-algorithm=sha256 name=vpn
/ip ipsec peer
add disabled=yes exchange-mode=ike2 name=vpn passive=yes profile=vpn
/ip ipsec proposal
add disabled=yes enc-algorithms=aes-256-cbc name=vpn pfs-group=none
add name=VLAN50 ranges=192.168.50.100-192.168.50.150
add name=VLAN60 ranges=192.168.60.100-192.168.60.150
add name=MGMT ranges=192.168.99.20-192.168.99.100
add name=VLAN30 ranges=192.168.30.100-192.168.30.150
add name=VLAN10 ranges=192.168.10.100-192.168.10.150
add name=VLAN20 ranges=192.168.20.100-192.168.20.150
add name=VLAN100-LAB ranges=10.10.10.100-10.10.10.150
add name=dhcp_pool18 ranges=10.10.10.100-10.10.10.150
add address-pool=VLAN50 interface=VLAN50 lease-time=10m name=VLAN50
add address-pool=VLAN60 interface=VLAN60 lease-time=10m name=VLAN60
add address-pool=MGMT interface=MGMT lease-time=10m name=MGMT
add address-pool=VLAN30 interface=VLAN30 lease-time=10m name=VLAN30
add address-pool=VLAN10 interface=VLAN10 lease-time=10m name=VLAN10
add address-pool=VLAN20 interface=VLAN20 lease-time=10m name=VLAN20
add address-pool=VLAN100-LAB interface=VLAN100-LAB lease-time=10m name=\
VLAN100-LAB
/port
set 0 name=serial0
set 1 name=serial1
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
add disabled=no name=default-v3 version=3
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
add disabled=yes instance=default-v3 name=backbone-v3
add bridge=bridge comment=defconf frame-types=\
admit-only-untagged-and-priority-tagged interface=ether3 \
internal-path-cost=10 path-cost=10 pvid=30
admit-only-untagged-and-priority-tagged interface=ether4 \
internal-path-cost=10 path-cost=10 pvid=60
admit-only-untagged-and-priority-tagged interface=ether6 \
admit-only-untagged-and-priority-tagged interface=ether7 \
admit-only-untagged-and-priority-tagged interface=ether9 \
internal-path-cost=10 path-cost=10 pvid=99
admit-only-untagged-and-priority-tagged interface=ether10 \
add bridge=bridge comment=defconf frame-types=admit-only-vlan-tagged \
interface=sfp-sfpplus1 internal-path-cost=10 path-cost=10
admit-only-untagged-and-priority-tagged interface=ether5 \
internal-path-cost=10 path-cost=10 pvid=50
add bridge=bridge frame-types=admit-only-vlan-tagged interface=ether8 \
set enabled=yes loose-tcp-tracking=no tcp-established-timeout=30m
set discover-interface-list=all
/ip settings
set max-neighbor-entries=4096 rp-filter=loose
/ipv6 settings
/interface bridge vlan
add bridge=bridge comment="VLAN 99" tagged=bridge,sfp-sfpplus1,ether8,ether10 \
untagged=ether9 vlan-ids=99
add bridge=bridge comment="VLAN 50" tagged=\
bridge,sfp-sfpplus1,ether10,*26,ether8 untagged=ether5 vlan-ids=50
add bridge=bridge comment="VLAN 60" tagged=bridge,sfp-sfpplus1,ether10,ether8 \
untagged=ether4 vlan-ids=60
add bridge=bridge tagged=bridge,sfp-sfpplus1,ether10,ether8 untagged=\
ether7,ether3 vlan-ids=30
add bridge=bridge tagged=bridge,sfp-sfpplus1,ether10,ether8 vlan-ids=10
add bridge=bridge tagged=bridge,sfp-sfpplus1,*26,ether10,ether8 vlan-ids=20
add bridge=bridge comment=LAB tagged=bridge,sfp-sfpplus1,ether10,*26 \
vlan-ids=100
add bridge=bridge vlan-ids=""
/interface detect-internet
set detect-interface-list=all
add comment=defconf disabled=yes interface=bridge list=LAN
add comment=defconf interface=ether1-WAN list=WAN
add interface=VLAN50 list=VLAN
add interface=VLAN60 list=VLAN
add interface=VLAN30 list=VLAN
add interface=VLAN10 list=VLAN
add interface=VLAN20 list=VLAN
add disabled=yes interface=bridge list=Winbox
add interface=MGMT list=Winbox
add interface=VLAN30 list=Winbox
add interface=ether2-access list=Winbox
add interface=MGMT list=VLAN
add interface=VLAN100-LAB list=VLAN
add interface=*26 list=Wifi
/interface ovpn-server server
set auth=sha1,md5
/interface wifi cap
set discovery-interfaces=bridge
/interface wifi capsman
set enabled=yes interfaces=bridge package-path="" require-peer-certificate=no \
upgrade-policy=none
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no master-configuration=Trusted \
name-format="" radio-mac=78:9A:18:10:9E:7D slave-configurations=IoT,Guest
name-format="" radio-mac=78:9A:18:10:9E:7C slave-configurations=IoT,Guest
add address=192.168.88.1/24 comment=defconf disabled=yes interface=bridge \
network=192.168.88.0
add address=192.168.99.1/24 comment=MGMT interface=MGMT network=192.168.99.0
add address=192.168.50.1/24 comment=WORK interface=VLAN50 network=\
192.168.50.0
add address=192.168.60.1/24 comment="Untrusted LAN" interface=VLAN60 network=\
192.168.60.0
add address=192.168.30.1/24 comment=Data interface=VLAN30 network=\
192.168.30.0
add address=192.168.10.1/24 comment=Hyper interface=VLAN10 network=\
192.168.10.0
add address=192.168.20.1/24 comment=Servers interface=VLAN20 network=\
192.168.20.0
add address=192.168.5.1/24 interface=ether2-access network=192.168.5.0
add address=10.10.10.1/24 comment=LAB interface=VLAN100-LAB network=\
10.10.10.0
/ip cloud
set ddns-enabled=yes update-time=no
/ip dhcp-client
add interface=ether1-WAN use-peer-dns=no
add address-pool=*1 disabled=yes interface=bridge lease-time=10m name=defconf
/ip dhcp-server lease
add address=192.168.30.103 client-id=1:74:d8:3e:8b:f4:89 mac-address=\
74:D8:3E:8B:F4:89 server=VLAN30
add address=192.168.30.109 client-id=1:9c:3d:cf:c:8f:c0 mac-address=\
9C:3D:CF:0C:8F:C0 server=VLAN30
add address=192.168.50.100 client-id=1:d8:bb:c1:7a:37:81 mac-address=\
D8:BB:C1:7A:37:81 server=VLAN50
add address=192.168.88.254 client-id=1:0:2b:67:c9:3f:7 mac-address=\
00:2B:67:C9:3F:07 server=defconf
add address=192.168.20.100 client-id=\
ff:7f:2a:fd:a7:0:1:0:1:2b:88:c8:3e:0:c:29:52:36:5b mac-address=\
9E:E2:7F:2A:FD:A7 server=VLAN20
add address=10.10.10.0/24 dns-server=10.10.10.1 gateway=10.10.10.1
add address=192.168.10.0/24 comment=Hyper gateway=192.168.10.1
add address=192.168.20.0/24 comment=Server gateway=192.168.20.1
add address=192.168.30.0/24 comment=Data dns-server=192.168.20.5 gateway=\
192.168.30.1
add address=192.168.50.0/24 comment=Work gateway=192.168.50.1
add address=192.168.60.0/24 comment="Untrusted LAN" gateway=192.168.60.1
add address=192.168.99.0/24 comment=MGMT gateway=192.168.99.1
set allow-remote-requests=yes cache-max-ttl=30m max-concurrent-queries=1000 \
max-concurrent-tcp-sessions=2000 servers=1.1.1.1 use-doh-server=\
https://cloudflare-dns.com/dns-query verify-doh-cert=yes
/ip dns static
add address=104.16.248.249 name=cloudflare-dns.com
add address=104.16.249.249 name=cloudflare-dns.com
/ip firewall address-list
established,related,untracked
add action=drop chain=input comment="defconf: drop invalid for input chain" \
connection-state=invalid log=yes log-prefix=\
"defconf: drop invalid input chain"
add action=accept chain=input comment="defconf: accept ICMP" in-interface=\
!ether1-WAN protocol=icmp
"defconf: accept to local loopback (for CAPsMAN,RADUIS,User manager..)" \
dst-address=127.0.0.1 log=yes log-prefix="ACCEPT - CAPsMan local ip"
add action=accept chain=input dst-port=8291,8844 in-interface=!ether1-WAN \
log=yes log-prefix=WinboxNOTwan protocol=tcp src-address-list=\
allowed_to_router
add action=accept chain=input comment="CAPSMANAGER Discovery" dst-port=\
5246,5247 protocol=udp
add action=accept chain=input comment="CAPSMANAGER Discovery" protocol=udp \
src-port=5246,5247
add action=accept chain=input comment="Allow LAN DNS queries-UDP BRIDGE" \
dst-port=53,123 in-interface-list=VLAN log=yes log-prefix=\
"Allow UDP DNS bridge" protocol=udp
add action=accept chain=input comment="Allow LAN DNS queries-TCP BRIDGE" \
dst-port=53 in-interface-list=VLAN log=yes log-prefix=\
"TCP DNS for VLANS bridge" protocol=tcp
"IP addresses that are allowed to access the router" log=yes log-prefix=\
Winbox src-address-list=allowed_to_router
add action=accept chain=input comment="EMERGENCY WINBOX ACCESS - ETH2" \
in-interface=ether2-access src-address=192.168.5.55
add action=reject chain=input comment="useful for tracking LAN issues" \
in-interface-list=VLAN log=yes log-prefix="icmp prohibited" reject-with=\
icmp-admin-prohibited
add action=accept chain=input log=yes log-prefix="ACCEPT - AP src mac" \
src-mac-address=78:9A:18:10:9E:7A
add action=drop chain=input comment="Drop All Else" log=yes log-prefix=\
"Drop All Else"
add action=accept chain=forward comment="DNS server udp" dst-address-list=\
DNS01 dst-port=53 in-interface-list=VLAN log=yes log-prefix=\
"DNS server udp" protocol=udp
add action=accept chain=forward comment="DNS server tcp" dst-address-list=\
"DNS server tcp" protocol=tcp
add action=accept chain=forward dst-port=22,3389,5901 in-interface=VLAN30 \
log=yes log-prefix="SSH out" out-interface=ether1-WAN protocol=tcp
add action=accept chain=forward comment="VLAN Internet Access only!" \
connection-state=new in-interface-list=VLAN out-interface-list=WAN
add action=accept chain=forward dst-address-list=VLAN100-LABRouter \
src-address-list=allowed_to_LAB
add action=accept chain=forward comment="WORK PC to Prox Home Servers" \
dst-address-list="Prox Home" dst-port=8006,8007 protocol=tcp \
src-address-list=WORKPC
add action=drop chain=forward dst-address-list=!WORK src-address-list=WORK
add action=accept chain=forward comment="VLAN30 to ProxMox Mgmt interface" \
dst-address-list=VLAN20 dst-port=8006,80,443,9443,3389,5900,5901,8007 \
protocol=tcp src-address-list=VLAN30
dst-address-list=VLAN20 dst-port=8006,8007 protocol=tcp src-address-list=\
MGMT_address
add action=accept chain=forward comment="Aruba Switch Admin page" \
dst-address-list="ARUBAS SWITCH" dst-port=4343 log=yes log-prefix=\
"Aruba Web Interface" protocol=tcp src-address-list=allowed_to_router
add action=accept chain=forward comment="ICMP from Allowed to VLAN" log=yes \
log-prefix="ICMP Allowed list to VLAN" out-interface-list=VLAN protocol=\
icmp src-address-list=allowed_to_router
add action=accept chain=forward comment="Remote access to LAB Sonicwall" \
dst-address-list=VLAN100-LAB dst-port=80,443,4433 log=yes log-prefix=\
"VLAN100-LAB remote access" protocol=tcp src-address-list=\
allowed_to_router
add action=accept chain=forward comment="Proxmox FileServer Admin" \
dst-address=192.168.20.50 dst-port=9090 log=yes log-prefix=\
"To Proxmox File Server" protocol=tcp src-address-list=allowed_to_router
add action=accept chain=forward comment="VLAN30 to ProxMox ssh by IP" \
dst-address-list=VLAN20 dst-port=22 protocol=tcp src-address-list=VLAN30
add action=accept chain=forward dst-address-list=ProxMoxFileServer dst-port=\
445 protocol=tcp src-address-list=VLAN30
add action=accept chain=forward comment="To Wazuh TCP" dst-address-list=\
Ubuntu-Portainer dst-port=1514,1515,55000,9200 in-interface-list=VLAN \
log=yes log-prefix=DestWazuhTCP protocol=tcp
add action=accept chain=forward comment="To Wazuh UDP" dst-address-list=\
Ubuntu-Portainer dst-port=514 in-interface-list=VLAN log=yes log-prefix=\
DestWazuhUDP protocol=udp
add action=accept chain=forward dst-address=192.168.20.100 src-address=\
192.168.30.103
add action=reject chain=forward in-interface-list=LAN log=yes log-prefix=\
"ICMP prohibited" reject-with=icmp-admin-prohibited
add action=drop chain=forward comment="Drop All Else" log=yes log-prefix=\
"Drop All Else"
add action=drop chain=prerouting comment=\
"drop non-legit src-addresses hitting WAN side" in-interface-list=WAN \
src-address-list=unexpected-src-address-hitting-ISP
ipsec-policy=out,none log=yes log-prefix=NAT_MASQ_LAB out-interface=\
VLAN100-LAB
/ip firewall raw
add action=accept chain=prerouting comment="defconf: enable for transparent fi\
rewall to quickly disable RAW filtering without disabling all RAW rules" \
disabled=yes log=yes log-prefix="RAW FILTER DISABLED!!"
log=yes log-prefix="Incoming WAN invalid src addy" src-address-list=\
"drop non-legit dst-addresses hitting WAN side" dst-address-list=\
!expected-dst-address-to-my-ISP in-interface-list=WAN log=yes log-prefix=\
"Incoming WAN invalid dst addy"
"drop non-legit traffic coming from LAN" in-interface-list=LAN log=yes \
log-prefix="non-legit FROM LAN" src-address-list=\
!expected-address-from-LAN
add action=drop chain=prerouting comment="defconf: drop non global from WAN" \
in-interface-list=WAN src-address-list=bad_ipv4
add action=drop chain=prerouting comment="Non-LAN IP coming from LAN" \
in-interface-list=LAN log=yes log-prefix="Non-LAN ip coming from LAN" \
src-address-list=!LAN
/ip ipsec identity
add auth-method=digital-signature certificate="Home server2" comment=\
"Home client2" disabled=yes generate-policy=port-strict match-by=\
certificate mode-config=vpn peer=vpn policy-template-group=vpn \
remote-certificate="Home client2"
add auth-method=digital-signature certificate="Home server" comment=\
"Home client1" disabled=yes generate-policy=port-strict match-by=\
remote-certificate="Home client1"
/ip ipsec mode-config
add address-pool=*D name=vpn
/ip ipsec policy
set 0 disabled=yes
add disabled=yes dst-address=0.0.0.0/0 group=vpn proposal=vpn src-address=\
0.0.0.0/0 template=yes
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh port=20022
set www-ssl address=192.168.30.103/32,192.168.88.0/24,192.168.99.0/24 \
certificate=https-cert disabled=no port=8844 tls-version=only-1.2
set api disabled=yes
set winbox address=\
192.168.88.0/24,192.168.99.0/24,192.168.30.103/32,192.168.5.0/24
set api-ssl disabled=yes
/ip ssh
set host-key-size=4096 strong-crypto=yes
/ip traffic-flow
set interfaces=VLAN50
/ipv6 firewall address-list
add address=fd12:672e:6f65:8899::/64 list=allowed
add address=fe80::/16 list=allowed
add address=fe02::/48 list=allowed
add address=ff02::/16 comment=multicast list=allowed
add address=fe80::/10 comment="defconf: RFC6890 Linked-Scoped Unicast" list=\
no_forward_ipv6
add address=ff00::/8 comment="defconf: multicast" list=no_forward_ipv6
add address=::1/128 comment="defconf: RFC6890 lo" list=bad_ipv6
add address=::ffff:0.0.0.0/96 comment="defconf: RFC6890 IPv4 mapped" list=\
bad_ipv6
add address=2001::/23 comment="defconf: RFC6890" list=bad_ipv6
add address=2001:db8::/32 comment="defconf: RFC6890 documentation" list=\
bad_ipv6
add address=2001:10::/28 comment="defconf: RFC6890 orchid" list=bad_ipv6
add address=100::/64 comment="defconf: RFC6890 Discard-only" list=\
not_global_ipv6
add address=2001::/32 comment="defconf: RFC6890 TEREDO" list=not_global_ipv6
add address=2001:2::/48 comment="defconf: RFC6890 Benchmark" list=\
not_global_ipv6
add address=fc00::/7 comment="defconf: RFC6890 Unique-Local" list=\
not_global_ipv6
add address=::/128 comment="defconf: unspecified" list=bad_dst_ipv6
/ipv6 firewall filter
"defconf: allow established, related, untracked" connection-state=\
connection-state=invalid log=yes log-prefix=ipv6,invalid
add action=drop chain=forward comment="defconf: drop bad forward IPs" \
src-address-list=no_forward_ipv6
dst-address-list=no_forward_ipv6
add action=accept chain=input comment="accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
"accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp \
src-address=fe80::/16
add action=drop chain=input disabled=yes in-interface=ether1-WAN log=yes \
log-prefix=dropLL_from_public src-address=fe80::/16
add action=accept chain=input comment="allow allowed addresses" \
add action=accept chain=forward comment=established,related connection-state=\
established,related
add action=accept chain=forward comment="defconf: accepts icmpv6 after raw" \
in-interface=!ether1-WAN protocol=icmpv6
add action=drop chain=forward disabled=yes log-prefix=IPV6
protocol=udp
add action=accept chain=input comment="defconf: accept IPSec AH" protocol=\
ipsec-ah
add action=accept chain=input comment="defconf: accept IPSec ESP" protocol=\
ipsec-esp
"defconf: accept all that matches IPSec policy" ipsec-policy=in,ipsec
in-interface-list=!LAN
/ipv6 firewall raw
add action=accept chain=prerouting comment=\
"defconf: enable for transparent firewall"
add action=drop chain=prerouting comment="defconf: drop bogon IP's" \
src-address-list=bad_ipv6
/system clock
set time-zone-autodetect=no time-zone-name=America/New_York
/system identity
set name=RB4011
/system note
set note="Be Careful!" show-at-login=no
/system ntp client
set enabled=yes
/system ntp server
set broadcast=yes enabled=yes local-clock-stratum=4 manycast=yes \
use-local-clock=yes
/system ntp client servers
add address=162.159.200.1
add address=162.159.200.123
/system package update
set channel=testing
/system resource irq rps
set sfp-sfpplus1 disabled=no
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=Winbox
/tool mac-server ping
set enabled=no
/tool romon
set enabled=yes
CAP AX is connected to Ether10 on the RB4011
