cant get ip address from router
i downgrade the SEXTANT G-5HPnd to router os 4.17 and then i cant connect to the router with winbox
even i cant get valid lan ip from router to fix with netinstall
and in the windows lan details ipv4:no network access
what can i do? please help me
winbox can do mac-address based connection which works w/o valid IPv4 address.
according to this link, http://wiki.mikrotik.com/wiki/Manual:Default_Configurations, you should be able to access it from the
ethernet port, as i think mac-server is not active on “WAN” ports.
