My RB2011UiAS-2HnD-IN will not get an IP from my ISP. I’m using Comcast and I turned on logging and called Comcast, of course they say the offer no support to owner owned routers (Big Suprise) but I asked if they still support IPV4 and she said no. SOOOO. I think my problem is the router is trying to pull an IPV4 address… (Log looks like it is seeing an IPV6 address if i’m reading it correctly. (I hooked up to my current router and was able to pull an IPV4 address from that router’s DHCP)
What I would like to do is set up my WAN to pull the IPV6 address from the ISP, but I would like to still use IPV4 on my LAN. Is this possible and if so how does one set this up. I’m a computer guy but far from a networking guy so I’m fairly new on the network side and not quite ready to dive head first into IPV6 on my local network. I appreciate any help you can provide. Thanks.
