On my RB532 I have set up PCQ such that everyone who connects through the device should share 12M down and 8M up equally. The problem I’m having is that for whatever reason, I can’t get the unit to pass more than 5 meg down (6-6.5 meg if you include uploads). This is consistent no matter how many session I have flowing through the bridge. Has anyone run into this before? Thanks in advance!
Do you use wireless (which standard 802.11 a, b, g) or Ethernet ?
Make sure troughput is not limited by upstream provided as well.
Do you have any other queues ?
This is purely an ethernet bridge. I have no other queues. When I turn off the PCQ, I can push 37-39 meg through the bridge, so there aren’t any problems with my test environment, so I don’t think there are any issues there.
My goal is to have everything except for one ip address share the PCQ queue such that bandwidth gets evenly distributed among them. For testing purposes, I haven't enabled the Office rule, but it's irrelevant anyway. Thanks!
