Hi
I’m trying to get a
Vodafone K3765-Z
ATI
Manufacturer: ZTE INCORPORATED
Model: K3765-Z
Revision: BD_VDFP673A1V1.0.0B02
IMEI: 353679034292957
+GCAP: +CGSM,+FCLASS,+DS
OK
ATZ
OK
working on ROS 4.11 and 5.0RC1 on RB 433. But after dialing the connection is droped and the usb/serial port is inactive. I have to drag the stick to get the port working again.
02:12:21 async,debug usb2:1: sent ATH
02:12:21 async,debug usb2:1: rcvd OK
02:12:21 async,ppp,info Vodafone: initializing modem…
02:12:21 async,debug usb2:1: sent ATZ
02:12:21 async,debug usb2:1: sent ATQ0 V1 E0 S0=0 &C1 &D2 +FCLASS=0
02:12:21 async,debug usb2:1: sent AT+CGDCONT=1,“IP”,“web.vodafone.de”
02:12:26 async,ppp,info Vodafone: dialing out…
02:12:26 async,debug usb2:1: sent ATD99**1#
02:12:26 async,debug usb2:1: modem hung up
02:12:26 async,ppp,info Vodafone: terminating… - modem hunged up
02:12:26 async,ppp,debug Vodafone: LCP lowerdown
02:12:26 async,ppp,debug Vodafone: LCP down event in initial state
02:12:26 async,ppp,info Vodafone: disconnected
02:12:26 async,ppp,info Vodafone: initializing…
02:12:26 async,ppp,info Vodafone: reseting link…
02:12:26 async,ppp,info Vodafone: reseting link… - could not acquire serial port
02:12:27 async,ppp,info Vodafone: initializing…
02:12:27 async,ppp,info Vodafone: reseting link…
02:12:27 async,ppp,info Vodafone: reseting link… - could not acquire serial port
PPP-Client
0 name=“Vodafone” max-mtu=1500 max-mru=1500 mrru=disabled port=usb2
data-channel=1 info-channel=1 apn=“web.vodafone.de” pin=“” user=“guest”
password=“guest” profile=Vodafone phone=“99**1#” dial-command=“ATDT”
modem-init=“ATZ;ATQ0 V1 E0 S0=0 &C1 &D2 +FCLASS=0” null-modem=no
dial-on-demand=no add-default-route=no use-peer-dns=no
keepalive-timeout=10 allow=pap,chap,mschap1,mschap2
PPP-Profile:
1 name=“Vodafone” use-ipv6=yes use-mpls=default use-compression=default
use-vj-compression=default use-encryption=no only-one=yes
change-tcp-mss=default dns-server=139.7.30.125,139.7.30.126
