How do I get 2 PCs to talk to each other form either end of the network through the VPLS tunnel? Is there any particular way that my PCs have to be set up? Or the networks on either end have to be set up? Do they have to be in the same /24 network? Or not have IPs at all?
ANY help here is helpful!
I doubt any of you will have 9 750Gs lying around. BUT…if you do, ive attached the backup for them in a zip file. 9RoutersBackupOSPFandMPLS.zip (25 KB)
The answer is simple! You must bridge the vpls interface to something to use it! For example you can bridge the vpls interface and one ethernet port in a bridge1 interface.
You are in a lab scenario? In a production enviorment I semplify and run OSPF/MPLS only on router that need to partecipate becouse you can have some issue if networks grow.
