I have just installed MikroTik V4.0beta1 and am having problems getting the internet to work,
I have 2 nic cards installed
- 192.168.0.80 called To_Gateway (Connected directly to ADLS modem)
- 172.16.0.1 called To_Wireless (Connected directly to Linksys wireless router)
I have set up gateway 192.168.0.3
I can ping internet addresses from the mikrotik console
If I connect my laptop direct to ADSL modem I have internet access.
If I connect via wireless my laptop is automatically assigned a 172.16.0.X ip address and I and acces the wireless router and the use the winbox to access the MikroTik.
If I try to ping an internet ip address it times out.
If I try to ping a www address it says Ping request could not find www.google.com. Please check the name and try again.
If I ping www.google.com from the mikrotik console it works.
Please HELP!!!
