I’m assuming I am trying to import the private key that was created by the router when I generated the certificate request. If that is not correct then the wiki is unclear.
OK… someone needs to modify those instructions on the OpenVPN certificate stuff. The key that the MT generates is a pkcs8 format and it specifically states on the wiki:
Warning: RouterOS does not support keys in pkcs8 format. To import keys in pkcs8 format run command:
openssl rsa -in myKey.key -text and write key output to new file. Upload new file to RouterOS and import
So… if I take the private key off the router and run that command using openssl then it works. Someone needs to modify the instructions for the openvpn article to reflect that.
Email support@mikrotik.com with a link to here and raise a documentation bug to make sure it gets fixed. These are user forums - staff may or may not read the forums.
it’s user part of Wiki, so anyone can edit it - just register
Thanks… I already tried though - I can’t find a link to register for the wiki. Only a log in link. I went to the main page as well - still no option to register. Maybe I’m missing something.
I sent a note to support@microtik.com to update it. I don’t know if/when it will happen but it’s kind of important since people will spend unnecessary amounts of time trying to make something work where just an additional bit of information will save them some time.
