Hi. I’m a beginner. Please help me set up OpenVPN.
The root of the problem : my router does not see the TLS certificate.
RouterOS Version: 7.16
model = C53UiG+5HPaxD2HPaxD
History:
I tried to set up openvpn using a file.the ovpn that my vpn provider gave me. At first, I tried to import certificates manually by splitting the configuration blocks into 2 files, the first one is , the second one is . The router accepted the first file normally, but refuses to recognize the second one. I also tried to use automatic import via the terminal, but the problem remains the CA certificate is accepted, but tls is not. Which is why I get an error when connecting " vpn-import1727395570: terminating… - TLS error: no key for certificate found (6)"
I smoked all the manuals, played with the extension.key / .pem doesn’t help anything.
Configuration from the provider(.ovpn):
client
auth-user-pass
proto udp
explicit-exit-notify
remote someserver 443
dev tun
resolv-retry infinite
nobind
persist-key
persist-tun
remote-cert-tls server
verify-x509-name **ELIDED** name
auth SHA256
auth-nocache
cipher AES-128-GCM
tls-client
tls-version-min 1.2
tls-cipher TLS-ECDHE-ECDSA-WITH-AES-128-GCM-SHA256
ignore-unknown-option block-outside-dns
verb 3
route-delay 11
<ca>
-----BEGIN CERTIFICATE-----
**ELIDED**
-----END CERTIFICATE-----
</ca>
key-direction 1
<tls-auth>
# 2048 bit OpenVPN static key
-----BEGIN OpenVPN Static key V1-----
**ELIDED**
-----END OpenVPN Static key V1-----
</tls-auth>
