Can't keep a mac or ip based winbox session
We have many RB532, 333 and 433’s in the field as AP’s. We have a problem with one and I can’t seem to figure out what the heck is going on with it.
We operate a bridged network and this particular AP will allow me to connect to the management ip but it comes up with a connection refused message… secondly when I connect via MAC using winbox it randomly disconnects.
I compared the interfaces tab and it is the only ap on my network that when you hit the interface tab then double click ether1 it show a master port option which is set to 0 and a switch field which shows 0…
Do you think this may be related to my problem…
that Mac connection disconnects - is completely normal, Mac winbox connection is not reliable and should only be used to add an IP address.
About IP connection I’m not sure, I don’t think I’ve seen any winbox that randomly disconnects over Ip …
