Can't Log in through Winbox
Am new, i removed my IP in my Mikrotik router 750gl and i can’t log in again with winbox . Can someone help me for the solution. thank you
use webfig
Use mac address for connection via winbox.
…and then go to IP → Services and see if you have accidentially masked out your own IP range in “avalaible from” for Winbox (and if it is active)
Then you might also want to check Tools → MAC Server and have a look at Winbox Interfaces.
And have a look at the group your user account is in if “winbox” is enabled for this group.
-Chris
You understand my answer.
Bravo!. :astonished:
