Hi!
I have mikrotik hap ac3 router with 7.1.3 routeros but I can’t login.
Hard reset - nothing.
Winbox - ip 0.0.0.0 and can’t login
webinterface - the same
Netinstall in Windows don’t show the pacages and only 6.49.2
Help me, please.
Hi!
Help me, please.
Use WinBos.
Refresh, look for router, click MAC address to use it instead of IP which is not set, log in, configure
When I put WinBos into google it asked me: Did you mean winBox ??
WinBox indeed.
If you have another Mikrotik router, then there is also MAC Telnet and MAC ssh in Tools, to connect without IP address.
MAC access requires both devices to be on the same L2 network (no routers in between)
Use/Clicq “Neigbors” MAC column
I have this problem too. When I make Reset Configuration, can’t login on winbox or webinterface. Only on phone work. I try few times.
7.1.3 Stable // MikroTik hAP ac3 (RBD53iG-5HacD2HnD)
It was test to check where 404 comes from ![]()
Apparently I am the answer to most mistakes LOL
Now is working good.
Flashing from Windows 10 with 2 or 3 attempts.
