I just setup a new SXTsq Lite2 as a bridge on my home network. It is up and running but now I can’t login to the router. I can see the IP, and ping it but the browser just times out. Winbox sees the router IP and MAC but cannot connect to either - just says it cannot connect. I have reset the router back to default a couple of times but somewhere during the config process I can no longer connect via the browser. The Winbox session remains up so the config process can be completed but once I end that session I am stuck again. Any ideas what is going wrong? Am I setting something that causes this? The router seems to function ok and I can access the equipment on the other side of the bridge although there is an issue that I haven’t yet resolved in that a PC on the other side of the bridge can’t access the internet but I can’t see that this should affect logging into the router?
Can you post the config you are running on it?
Could be something to do with the interface lists and winbox access set to the wlan
I have attached the backup I made if this will help! Thanks.
MikroTik.zip (5.23 KB)
Hi Derek,
Can you do a command export file=PTP-AC hide-sensitive in the terminal of the SXT
Open the file with notepad++ and copy paste contents here or attach the file.
That doesn’t work either. I can’t connect via Telnet … The router is working fine and I can see and ping it on the network.
C:\Users\Derek>telnet 192.168.8.253 23
Connecting To 192.168.8.253…Could not open connection to the host, on port 23: Connect failed
C:\Users\Derek>ping 192.168.8.253
Pinging 192.168.8.253 with 32 bytes of data:
Reply from 192.168.8.253: bytes=32 time=1ms TTL=64
Reply from 192.168.8.253: bytes=32 time=2ms TTL=64
Ping statistics for 192.168.8.253:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 2ms, Average = 1ms
Ok, what is it you are trying to do with the SXTsq Lite2?
Is it possible for you to reset the device and remove the default setup script.
I can assist you to setup the device without the help of quickset.
I use it to bridge my network between the house and the workshop. I have a TPLink access point running in client mode in the workshop. Whatever setup I did on the SXT works perfectly - I can access internet and the network devices from the workshop and I can access devices from the house. I used these instructions https://wiki.mikrotik.com/wiki/Manual:Initial_Configuration but since these contemplate a router with more than one ethernet port maybe I did something wrong that prevents me accessing the unit via IP or MAC.
On resetting the unit that is possible and it would be great to get help from someone who actually understands all these things! As mentioned it is working fine but I just don’t like not being able to access the unit! We would just need to coordinate to do this at a time that suits you.
The SXT you are using is has a licensed 3 so the wireless will be set to “bridge” mode for one only one wireless device to connect which is the workshop device.
The script below has set the wireless security to workshopconnect so on the TP device in the work shop you will need to search for SSID PTP-Workshop-Bridge
and connect using the wireless security workshopconnect
You must reset the SXT to default and do not use the default configuration once you have reset the device.
So when you reset the SXT and log into the SXT, click remove default script and you might be kicked back out of the SXT.
Just connect back in using the MAC of the SXT.
Below is a script that you will have to paste into the terminal of the SXT device.
The script below assumes that the ethernet port of the SXT is named ether1 and wlan port is named wlan1.
add name=WirelessLAN
add bridge=WirelessLAN interface=ether1
add bridge=WirelessLAN interface=wlan1
/ip dhcp-client add interface=ether1 disabled=no
/interface wireless
set [ find default-name=wlan1 ] frequency=auto band=2ghz-b/g/n channel-width=20/40mhz-eC mode=bridge ssid=“PTP-Workshop-Bridge” wireless-protocol=802.11 default security-profile=default
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods=“” mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=workshopconnect wpa2-pre-shared-key=workshopconnect
/tool romon
set enabled=yes
Hope this helps
Thanks Flynno - I will give this a go at the first opportunity I get!
I hope you don’t mind me joining in–I don’t meant to hijack the thread–but I am having a very similar problem with my Metal 52ac.
The setup I am aiming for is as a wifi ap-bridge to the wired network (ultimately this will be used in a closed network with no wan access). No NAT, no DHCP client (although it will become a DHCP server later on).
I think I have all the settings correct, but when I enable the bridge (with eth0 and wlan0 ports) then the wifi-lan bridging starts to work successfully, but at the same time I loose all access to WebFig (I’m on a Mac, so no Winbox). I have found that an existing ssh session stays live so I can now at least disable the bridge rather than reset and start all over (which I have done too many times now!).
Here is the current config, with the bridge disabled. Any help gratefully received.
# jan/21/2019 14:48:21 by RouterOS 6.43.8
# software id = 1K4A-AQNN
# model = Metal G-52SHPacn
# serial number = A80809E0DBD5
add disabled=yes fast-forward=no name=bridge1
set [ find default-name=ether1 ] speed=100Mbps
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa2-psk management-protection=allowed mode=\
dynamic-keys name=blue_planet supplicant-identity=MikroTik
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-Ceee disabled=no frequency=auto mode=ap-bridge \
security-profile=blue_planet ssid="Video World"
/ip hotspot profile
add name=default-dhcp ranges=192.168.1.101-192.168.1.254
add address-pool=default-dhcp disabled=no interface=wlan1 name=defconf
add address-pool=default-dhcp interface=wlan1 name=server1
add bridge=bridge1 interface=LAN
add comment=defconf interface=ether1 list=LAN
add interface=wlan1 list=LAN
add address=192.168.1.3/24 comment=sph interface=ether1 network=192.168.1.0
add address=192.168.1.0/24 comment=defconf gateway=192.168.1.1
set allow-remote-requests=yes servers=192.168.1.1
/ip dns static
add address=192.168.88.1 name=router.lan
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add distance=1 gateway=192.168.1.1
/system clock
set time-zone-name=Europe/London
/syste
m ntp client
set enabled=yes
/tool mac-server
/tool mac-server mac-winbox
Maybe I have stumbled upon solution.
I have had the same problem with couple of Disc lite5.
After setting device as ap-bridge, it becomes invisible to winbox and ping.
Station side, I could connect to bridge-ap only by MAC.
AP side wise, ap-bridge was completely invisible.
Comparing setups I have found that interface list of station-bridge is fine but interface list of bridge-ap misses “bridge”.
Add mannualy “bridge” and set as LAN.
After that, ap-bridge is fully available from both sides by IP or MAC.
helloo
This advice of yours helped me a lot, I have 2 pieces RouterBOARD SXTsq 5HPnD works like ptp and now everything works for me, thanks.
