Can't login to routeros becouse of different port
I changed all my ports ini /ip services, but now i can’t connect to them from dude anymore… Any solution?
use winbox via MAC address, and check what ports you have set there
I know the port, i cant log on MT via winbox, thats works ok, but how to change port on Dude? He now wan’t connect
you can’t change the port. but you can make a new “tool” with the correct port specified. then you will have two tools - regular winbox, and winbox with changed port. see similar issue here:
http://forum.mikrotik.com/t/using-tool-winbox-later-specify-user/23349/1
I like to change the ports to my MK router (winbox 8291), and still have the all RouterOS tab working properly in The Dude. Are there any solution for it ?
Yes, but in Devices it it shown as down. Not reachable.
Which probe is showing down? You might need to recreate your own version of the probe so that it returns true when the probe checks that the service you are trying to monitor is up…
