Hello
After upgrade I can’t seem to logon via wlan using winbox.
I can mac telenet and have web access,
Any Idea’s?
Thanks ![]()
“Edited for clarification”
Hello
Any Idea’s?
Thanks ![]()
you cannot login using winbox or wlan? or both? please be more specific
I edited the post.
I cannot use winbox to logon to the system via the systems wlan port.
I have not tried the ether ports as its a remote box
delete winbox and application data for winbox, download new one and try again
, some files became corrupted. usually cleaning them out helps
Hello, Thanks
This was 2 diffrent PC’s
I’ll download fresh one anyway but it does not even connect at all
