I installed 2.9.35 on a RB153 and now I can’t get to the terminal. I get the following error:
login: can’t resolve symbol ‘_ZN2nv8pohicies10set_policyEjj’
What do i do?
What do i do?
Did a reboot and now it is allowing me to login in? ![]()
it’s very..very nice six minutes only you has solved… ![]()
as in “The IT Crowd” -
1st option: is it plugged in?
2nd option: have you tried to restart it?
3rd: if first 2 does not work than theres should be error in configuration
4th: if there is no error in configuration - cheeck 3rd option
5th: try reset ![]()
janisk you are forgot, when all options can’t too…
last option, try to sell it… ![]()
