In my new RB750Gr3 just occured a problem with logging using MAC. When the device was delivered, with default configuration, I had no problem to log in using MAC address. After I created bridge and added ether2-master (with all slaves), I can’t use MAC address to log in any more. The bridge had to be created for CAPsMAN.
WinBox finds the device in “Neighbors”, I choose MAC to connect, but got “ERROR: could not connect to…”. What is the problem?
Check what you have in “/tool mac-server mac-winbox”. I always reset devices to blank config and that enables MAC server for all interfaces. But I think default config might have only selected interfaces there.
Here it is:
[admin@RB750Gr3] > /tool mac-server mac-winbox print
Flags: X - disabled, * - default
# INTERFACE
0 X* all
1 ether2-master
[matt@strych-router] >
I enabled “all” and it helped.
Thank you.
What happens, when winbox detects mac and IP 0.0.0.0 but error in connection via MAC, This happens in RB LHG 5nD. Reseted did not work. Where can I attach the print to the screen to show what happens.
When posting, look just below the [Save Draft] [Preview] [Submit] buttons.
You’ll see an Options tab; on its right, you’ll read “Attachments”, which is actually a tab where you’ll be able to Add files.
Thank you , for attention.
the problem is when in change button CPE for PTPbridge in RB LHG 5nD. the RB don´t come back more. I needed use Netinstall for aces again.
Thanks for the information on how to attach print screen
You need to use a modern Winbox to connect to most modern ROS version and mikrotik devices.
hi
I have this problem. I cant login with IP or MAC Address
don’t connect with winbox
don’t work telnet
