Can't login with admin on SXT
Hi I’m tryiing to login on my SXT with Winbox. When I try to login with default admin username and password (admin, and nothing as password, right?) it says wrong username and password. I can login with “default” as username, but when I’ve logged in with that I haven’t permission to do anyting. Please help, I’m a noob.
How are you resetting the device?
Make the reset. Then log by default admin.
How do I reset it?*
I would suggest jumping the reset point on the board with a screwdriver (or something else that is metal). It should be a small hole with metal semicircles around it. Hold the screwdriver on it when you connect power.It should make some odd beeps as it boots. After that login with admin no password.
Jumping the reset point?
This is the reset point.
Should it click or something when i but the skrewdriver in?
no you are trying to jump the two sides when power is connected at start.
Connect the two metalic things together so they like get eachothers electricity?
yes
Ok, I think I’ve done it now. Should it beep or something.
I still cant login as admin. Can this be because my ISP sent me it?
It is possible to pre-configure a device with netinstall which may be your only option.
http://wiki.mikrotik.com/wiki/Manual:Netinstall
