Hello people, i searched the forum but i couldn’t find a fix that worked for me so i decided to open a new thread.
currently i have two mikrotik routers connected together via ethernet, like this:
INTERNET (6 ADSL LINES) → RB2011iL (PCC+NAT) → RB450G (QUEUES+WEBPROXY) → SWITCH → USERS
my problem is i can’t reach the rb450g (172.16.0.10) over the internet when i port forward from the rb2011il.
this is the rb2011il config:
# jan/17/2015 21:32:06 by RouterOS 6.23
add address=172.16.0.1/24 interface="ether1 - SALIDA" network=172.16.0.0
/ip firewall address-list
add address=172.16.0.0/24 list=LAN_NAT
add chain=input dst-port=8291 protocol=tcp
add chain=input dst-port=53 protocol=udp
add chain=input dst-port=80 protocol=tcp
add chain=forward dst-port=53 protocol=udp
/ip firewall mangle
add chain=input comment=TEST disabled=yes in-interface="ether1 - SALIDA"
add action=mark-connection chain=input comment=Entrantes in-interface=\
pppoe-out1 new-connection-mark=pppoe-out1_conn
add action=mark-connection chain=input in-interface=pppoe-out2 \
new-connection-mark=pppoe-out2_conn
add action=mark-connection chain=input in-interface=pppoe-out3 \
new-connection-mark=pppoe-out3_conn
add action=mark-connection chain=input in-interface=pppoe-out4 \
new-connection-mark=pppoe-out4_conn
add action=mark-connection chain=input in-interface=pppoe-out5 \
new-connection-mark=pppoe-out5_conn
add action=mark-connection chain=input in-interface=pppoe-out6 \
new-connection-mark=pppoe-out6_conn
add action=mark-routing chain=output connection-mark=pppoe-out1_conn \
new-routing-mark=to_pppoe-out1 passthrough=no
add action=mark-routing chain=output connection-mark=pppoe-out2_conn \
new-routing-mark=to_pppoe-out2 passthrough=no
add action=mark-routing chain=output connection-mark=pppoe-out3_conn \
new-routing-mark=to_pppoe-out3 passthrough=no
add action=mark-routing chain=output connection-mark=pppoe-out4_conn \
new-routing-mark=to_pppoe-out4 passthrough=no
add action=mark-routing chain=output connection-mark=pppoe-out5_conn \
new-routing-mark=to_pppoe-out5 passthrough=no
add action=mark-routing chain=output connection-mark=pppoe-out6_conn \
new-routing-mark=to_pppoe-out6 passthrough=no
add action=mark-routing chain=prerouting comment=TEST2 disabled=yes \
in-interface=pppoe-out1 new-routing-mark=to_pppoe-out1 passthrough=no
add action=mark-routing chain=prerouting dst-address-list=!LAN_NAT \
in-interface="ether1 - SALIDA" new-routing-mark=to_pppoe-out1 \
passthrough=no per-connection-classifier=both-addresses:7/0 \
src-address-list=LAN_NAT
passthrough=no per-connection-classifier=both-addresses:7/1 \
in-interface="ether1 - SALIDA" new-routing-mark=to_pppoe-out2 \
passthrough=no per-connection-classifier=both-addresses:7/2 \
in-interface="ether1 - SALIDA" new-routing-mark=to_pppoe-out3 \
per-connection-classifier=both-addresses:7/3 src-address-list=LAN_NAT
in-interface="ether1 - SALIDA" new-routing-mark=to_pppoe-out4 \
per-connection-classifier=both-addresses:7/4 src-address-list=LAN_NAT
in-interface="ether1 - SALIDA" new-routing-mark=to_pppoe-out5 \
per-connection-classifier=both-addresses:7/5 src-address-list=LAN_NAT
in-interface="ether1 - SALIDA" new-routing-mark=to_pppoe-out6 \
per-connection-classifier=both-addresses:7/6 src-address-list=LAN_NAT
add action=masquerade chain=srcnat comment=NAT out-interface=pppoe-out1
add action=masquerade chain=srcnat out-interface=pppoe-out2
add action=masquerade chain=srcnat out-interface=pppoe-out3
add action=masquerade chain=srcnat out-interface=pppoe-out4
add action=masquerade chain=srcnat out-interface=pppoe-out5
add action=masquerade chain=srcnat out-interface=pppoe-out6
add action=dst-nat chain=dstnat dst-port=1414 in-interface="!ether1 - SALIDA" \
protocol=tcp to-addresses=172.16.0.10 to-ports=80
add distance=1 gateway=pppoe-out1 routing-mark=to_pppoe-out1
add distance=1 gateway=pppoe-out2 routing-mark=to_pppoe-out2
add distance=1 gateway=pppoe-out3 routing-mark=to_pppoe-out3
add distance=1 gateway=pppoe-out4 routing-mark=to_pppoe-out4
add distance=1 gateway=pppoe-out5 routing-mark=to_pppoe-out5
add distance=1 gateway=pppoe-out6 routing-mark=to_pppoe-out6
add distance=5 gateway=pppoe-out2
add distance=10 gateway=pppoe-out3
add distance=15 gateway=pppoe-out4
add distance=15 gateway=pppoe-out5
add distance=15 gateway=pppoe-out6
add check-gateway=ping distance=30 gateway=192.168.1.1
add check-gateway=ping distance=30 gateway=192.168.2.1
add check-gateway=ping distance=30 gateway=192.168.3.1
add check-gateway=ping distance=30 gateway=192.168.4.1
add check-gateway=ping distance=30 gateway=192.168.5.1
add check-gateway=ping distance=30 gateway=192.168.6.1
add distance=1 dst-address=10.10.37.0/24 gateway=10.10.37.10 scope=255
hope someone can give me some help on this ![]()
