Can't make port forwarding work for OpenVPN
I’m trying to setup basic port forwarding for OpenVPN:
add action=dst-nat chain=dstnat dst-port=22125 in-interface=bridge protocol=\
    tcp to-addresses=192.168.1.4 to-ports=22125
But it doesn’t connect when I’m trying to telnet to 22125 using my external IP. Connecting using local network IP works well.
The log (if enabled) shows:
dstnat: in:bridge out:(unknown 0), connection-state:new src-mac redacted, proto TCP (SYN), 192.168.1.4:50828->external_ip_redacted:22125, len 52
I tried specifying ether1 instead of bridge too and connecting from outside:
dstnat: in:ether1 out:(unknown 0), connection-state:new src-mac redacted, proto TCP (SYN), redacted:17020->external_ip_redacted:22125, len 60
My config:
oct/26/2023 11:24:09 by RouterOS 7.8
software id = YTB3-K1K6
model = RBD52G-5HacD2HnD
add admin-mac=redacted auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] mac-address=redacted2
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX
country=no_country_set disabled=no distance=indoors frequency=auto
installation=indoor mode=ap-bridge ssid=redacted-lan wireless-protocol=
802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=
20/40/80mhz-XXXX country=no_country_set disabled=no distance=indoors
frequency-mode=superchannel installation=indoor mode=ap-bridge ssid=
redacted-lan wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys
supplicant-identity=MikroTik
/ip hotspot profile
add name=dhcp ranges=192.168.1.50-192.168.1.254
add address-pool=dhcp interface=bridge name=defconf
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan1
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan2
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
add interface=lte1 list=WAN
/interface ovpn-server server
set auth=sha1,md5
add address=192.168.1.1/24 comment=defconf interface=bridge network=
192.168.1.0
add address=ext_ip_redacted/24 interface=ether1 network=ext_subnet_redacted0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
/ip dhcp-server lease
add address=192.168.1.6 client-id=1:redacted3 mac-address=
redacted3 server=defconf
add address=192.168.1.0/24 comment=defconf dns-server=192.168.1.1 gateway=
192.168.1.1 netmask=24
set allow-remote-requests=yes servers=8.8.8.8,1.1.1.1
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
add action=accept chain=input comment=
“defconf: accept established,related,untracked” connection-state=
add action=drop chain=input comment=“defconf: drop invalid” connection-state=
invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
“defconf: accept to local loopback (for CAPsMAN)” dst-address=127.0.0.1
add action=drop chain=input comment=“defconf: drop all not coming from LAN”
in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept in ipsec policy”
ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy”
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
“defconf: accept established,related, untracked” connection-state=
add action=drop chain=forward comment=“defconf: drop invalid”
connection-state=invalid
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
add action=masquerade chain=srcnat comment=“defconf: masquerade”
add disabled=no dst-address=0.0.0.0/0 gateway=ext_subnet_redacted1
/ip service
set telnet address=192.168.1.0/24 disabled=yes
set ftp address=192.168.1.0/24 disabled=yes
set www address=192.168.1.0/24
set ssh address=192.168.1.0/24 disabled=yes
set www-ssl address=192.168.1.0/24
set api address=192.168.1.0/24
set winbox address=192.168.1.0/24
set api-ssl address=192.168.1.0/24
/system clock
set time-zone-name=Europe/Kiev
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
Any help here?
yeah, dont get what you are trying to accomplish because the r equirement talk about the config which is bass ackwards.
Without discussing the config or network…
a. identify the user(s)/device(s) groups of users and devices
b. identify the traffic flows they require including the admin
Draw a network diagram!
NETWORK DIAGRAM APPS:
https://nulab.com/cacoo/
https://online.visual-paradigm.com/diagrams/solutions/free-network-diagram-software/
https://www.lucidchart.com/pages/
https://drawio-app.com/product/
https://www.diagrams.net/ (its older sibling soon to be discontinued https://drawio-app.com/product/)
( Other links for diagrams.net - https://www.youtube.com/watch?v=P3ieXjI7ZSk & https://www.youtube.com/watch?v=mpF1i9sfEJ0 )
https://sourceforge.net/projects/dia-installer/
https://www.yworks.com/products/yed (and icons for yed → https://github.com/danger89/yEd_cisco_network_icons )
https://www.libreoffice.org/discover/draw/
http://kilievich.com/fpinger/ - has a simple drawing program but not its main intent.
