Hello there.
I've setup a few mikrotiks as routers, they are behind a vdsl router, running in PPPoE. Something like this
Internet -- VDSL Router -- Mikrotik PPPoE --- LAN
I've enabled with success a few ports like web and winbox over the Internet to have a look on them
using the cloud hostname ***sn.mynetname.net and they are working.
But SNMP doesn't. Seems enabled:
/snmp community print
Flags: * - default
NAME ADDRESSES SECURITY READ-ACCESS
0 * public 0.0.0.0/0 none yes
1 natigon 0.0.0.0/0 none yes
/snmp print
enabled: yes
contact: info@natigon.gr
engine-id:
trap-target:
trap-community: natigon
trap-version: 1
trap-generators:
But snmpwalk returns error. Tried to forward 161 UDP port too but again with no success
Firewall configuration
/ip firewall filter print
0 D ;;; special dummy rule to show fasttrack counters
chain=forward action=passthrough
1 X ;;; defconf: fasttrack
chain=forward action=fasttrack-connection connection-state=established,related log=no log-prefix=""
2 X ;;; defconf: accept established,related
chain=forward action=accept connection-state=established,related log=no log-prefix=""
3 X ;;; defconf: drop invalid
chain=forward action=drop connection-state=invalid log=no log-prefix=""
4 X ;;; defconf: drop all from WAN not DSTNATed
chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface=ether1 log=no log-prefix=""
5 X chain=input action=accept protocol=icmp log=no log-prefix=""
6 X chain=input action=accept connection-state=established log=no log-prefix=""
7 X chain=input action=accept connection-state=related log=no log-prefix=""
8 X ;;; allow l2tp
chain=input action=accept protocol=udp dst-port=1701 log=no log-prefix=""
9 X ;;; allow pptp
chain=input action=accept protocol=tcp dst-port=1723 log=no log-prefix=""
10 X ;;; allow sstp
chain=input action=accept protocol=tcp dst-port=443 log=no log-prefix=""
11 X chain=input action=drop in-interface=pppoe-out1 log=no log-prefix=""
And the port forwarder
/ip firewall nat> print
0 ;;; defconf: masquerade
chain=srcnat action=masquerade out-interface=pppoe-out1 log=no log-prefix=""
1 ;;; masq. vpn traffic
chain=srcnat action=masquerade src-address=192.168.89.0/24 log=no log-prefix=""
2 chain=dstnat action=dst-nat to-addresses=192.168.2.1 to-ports=161 protocol=udp in-interface=pppoe-out1 dst-port=161
On any protocol snmpwalk returns nothing.
[root@freedom ~]# snmpwalk -Os -c public -v 1 642e05e1fe93.sn.mynetname.net
Timeout: No Response from 642e05e1fe93.sn.mynetname.net
[root@freedom ~]# snmpwalk -Os -c public -v 2c 642e05e1fe93.sn.mynetname.net
[root@freedom ~]# snmpwalk -Os -c public -v 3 642e05e1fe93.sn.mynetname.net
snmpwalk: Timeout
[root@freedom ~]#Any thoughts ?
As a second way I thought to create VPNs, but both my office and these locations have dynamic IPs so it makes it a bit more complicated.
