Can't make VLANs to work with RB30011 (cant get PI addres from dhcp)
I have already found multiple topics like this but none of them helped me. What I’m trying to achive is to set my geust Wifi (using Unifi unifi ap-ac-pro) and mikrotik RB30011UiAS. All my devices are currently connected to ether2 and my internet connection is connected to ether1.
What I curently did:
1. Enable VLAN for one of my Wifi networks:
2. Created VLAN interface:
3. Assigning new address on vlan interface
4. Setting up DHCP server for that interface:
5. Bridge / VLAN settings:
Here I’m not sure, I was just looking at the solution on the topic http://forum.mikrotik.com/t/cant-get-vlans-to-work-solved/117626/1
6. Enable vlan filtering on the bridge interface:
Now when I want to connect to my geuest network (that uses vlan10) I get no IP address. What do I miss?
As you are using a VLAN-aware bridge:
The VLAN interface created in #2 should be attached to bridge-lan NOT ether2
When setting up the DHCP server in #4 you need to create an entry under the Network tab too
The bridge VLAN settings in #5 are not correct, the entry for VLAN 10 should have tagged=bridge-lan,ether2 and no untagged entries
Thank you for answer! I have changed the config as you mentioned but nothing has changed. I’m still not able to get and IP from DHCP when connected to geuest network. Also looking at the interface list I can see no traffic on vlan10. Changes I made:
#2
Attaching vlan interface to bridge:
#4
I had an entry in Network tab:
#5
Fixing bridge vlan settings (cannot remove vlan10 from Untagged for vlan id 10):
Any other place I should update or anything else I’m missing?
The current untagged vlan10 entry is incorrect, it may be cleared by a reboot.
Note that vlan10 should not be included under Bridge>Ports, the output of /export hide-sensitive would be more useful than a selection of screenshots.
You’re right, I forgot I have added also vlan10 into Bridge > Ports. Removing it from there automatically removed vlan10 from Untagged. But still it’s not working :frowning:
Here is the output you’ve asked for:
[admin@MikroTik] >> export hide-sensitive
# oct/04/2019 18:58:42 by RouterOS 6.45.1
# software id = JJDI-22UL
# model = RouterBOARD 3011UiAS
# serial number = 8EEA09C227E2
add admin-mac=B8:69:F4:2F:73:7E auto-mac=no comment=defconf name=bridge-lan vlan-filtering=yes
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 use-peer-dns=yes user=xxx
/interface vlan
add interface=bridge-lan name=vlan10 use-service-tag=yes vlan-id=10
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=dhcp_pool2 ranges=192.168.10.2-192.168.10.254
add address-pool=dhcp disabled=no interface=bridge-lan lease-time=1d name=defconf
add address-pool=dhcp_pool2 disabled=no interface=vlan10 lease-time=20m name=dhcp1
add bridge=bridge-lan comment=defconf interface=ether2
add bridge=bridge-lan comment=defconf interface=ether3
add bridge=bridge-lan comment=defconf interface=ether4
add bridge=bridge-lan comment=defconf interface=ether5
add bridge=bridge-lan comment=defconf interface=ether6
add bridge=bridge-lan comment=defconf interface=ether7
add bridge=bridge-lan comment=defconf interface=ether8
add bridge=bridge-lan comment=defconf interface=ether9
add bridge=bridge-lan comment=defconf interface=sfp1
/interface bridge vlan
add bridge=bridge-lan tagged=ether1 untagged=bridge-lan vlan-ids=1
add bridge=bridge-lan tagged=bridge-lan,ether2 vlan-ids=10
add independent-learning=no ports=ether2 switch=switch1 vlan-id=1
add independent-learning=no ports=ether2 switch=switch1 vlan-id=10
add comment=defconf interface=bridge-lan list=LAN
add address=192.168.88.1/24 comment=defconf interface=ether2 network=192.168.88.0
add address=192.168.10.1/24 interface=vlan10 network=192.168.10.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1
/ip dhcp-server lease
add address=192.168.88.23 comment="Satel ETHM-1" mac-address=00:1B:9C:09:50:B8 server=defconf
add address=192.168.88.22 client-id=1:0:25:22:af:f0:53 comment="Desktop w gabinecie" mac-address=00:25:22:AF:F0:53 server=defconf
add address=192.168.10.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.10.1
add address=192.168.88.0/24 comment=defconf dns-server=8.8.8.8,8.8.4.4 gateway=192.168.88.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/system clock
set time-zone-name=Europe/London
/tool mac-server
/tool mac-server mac-winbox
A few things:
Uncheck ‘Use service VLAN’ in the configuration for vlan10 - it should be a regular 802.1Q VLAN rather than an 802.1ad (service) VLAN.
Remove the entries under /interface ethernet switch vlan - it is possible to mix a non-VLAN aware bridge with hardware switching and VLAN filtering, but unless you need wirespeed switching it should be avoided as there can be weird interactions.
The vlan10 interface isn’t a member of the LAN interface list unless you add it - the default rule to drop input from anything not in the LAN interface list will prevent access to the router from the new VLAN, ICMP is permitted by an earlier rule and as far as I can remember DHCP should work as it uses raw rather than IP sockets.
Thanks @tdw. I made changes you suggested but it still not working. Current config:
[admin@MikroTik] > export hide-sensitive
# oct/04/2019 22:47:26 by RouterOS 6.45.1
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 use-peer-dns=yes user=rzeczna81f@dg-net.pl
/interface vlan
add interface=bridge-lan name=vlan10 vlan-id=10
add interface=vlan10 list=LAN
/ip dhcp-client
/ip dns static
/system clock
/tool mac-server
Any other clue?
  1. I think you have a static DNS setting left over from the default quick setup (should be removed).
  2. Not sure why you have a VLAN BRIDGE setting for ether1 and vlan1? (it serves no purpose that I can see)
  3. What is the purpose of identifying all the bridge ports 3-sfp1 (what is on those ports and what IP do they get which leads me to
  4. Change the ip address assignment from ether 2, to the bridge-lan interface!! (192.168.88…)
All those settings are default ones. Currently nothing is connected to ports from ether3 - to sfp1. After work I will adjust the settings according to your hints and I will share the results, thanks!
I made all changes you have mentioned… stil not working :confused: Current settings:
# oct/07/2019 20:57:12 by RouterOS 6.45.1
/interface vlan
add address=192.168.88.1/24 comment=defconf interface=bridge-lan network=192.168.88.0
/ip dhcp-client
/system clock
/tool mac-server
Please untag ether2 and try again…
add bridge=bridge-lan tagged=bridge-lan untagged=ether2 vlan-ids=10
Hi complex, the reason I didnt untag ether 2 is due to two reasons, first because its acting as a trunk port for vlan10 and the default vlan1.
I am assuming his ubiquiti devices are able to assign vlan10 to attached devices.
Hi anav,
In the latest configuration update I do not see any vlan1 setup.
Also I assuming that his ubiquiti device is not able to assign any vlan to the attached devices, thats why the devices get no IP address from DHCP pool.
If you untag ether2 then all devices should get an IP address.
This is my humble opinion.
VLAN1 is the default, it is assumed by the router.
The DHCP on the VLAN is all setup on the MT, it does give out IP addresses to any device connected on vlan10.
The ubiquities are advanced access points, they have VLAN capabilities similar to the CapACs I use which assign VLAN tags to incoming data.
I just assign trunk ports to capacs…
This is correct.
My Ubiquiti UniFi AP, AC PRO should have a capabilities to assign vlan10 to attached devices, but is there a way to test if it works correctly?
Tried that and it didn’t work - same effect - cannot get IP from dhcp. All devices connected to any other wifi networks gets IP correctly, only the ones connected to the guest wifi - vlan10 cannot get ip. Is there a way to test vlan connection?
In the original post I see a screenshot from “Interface ” where you have “Use Service Tag” enabled.
Please disable this Service Tag and try again?
One more thing what you can try is to connect a PC to port 4 by wire.
Then change/set and check if the PC gets a DHCP address.
add bridge=bridge-lan interface=ether2
add bridge=bridge-lan tagged=bridge-lan,ether2 untagged=ether4 vlan-ids=10
set bridge=bridge-lan ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged pvid=10 [find interface=ether4]
Sorry for late reply but I got so busy at work for the last month that I had no time to play with it. Now I came back to it and I decided to reset the MT config and start from the begining, but with no success. Same result.
My config is:
# nov/03/2019 21:22:17 by RouterOS 6.45.1
add admin-mac=B8:69:F4:2F:73:7E auto-mac=no comment=defconf name=bridge vlan-filtering=yes
/interface vlan
add interface=bridge name=vlan10 vlan-id=10
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge tagged=bridge,ether2 vlan-ids=10
/ip dhcp-client
add address=192.168.10.0/24 gateway=192.168.10.1
/ip dns static
/system clock
set time-zone-name=Europe/Warsaw
/tool mac-server
I have tried to connect to the guest WiFi (vlan10) with statically set IP and no luck. I have also tried @complex1 hint:
New config:
# nov/03/2019 21:38:16 by RouterOS 6.45.1
/interface vlan
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=yes interface=ether4 pvid=10
add bridge=bridge tagged=bridge,ether2 untagged=ether4 vlan-ids=10
/ip dhcp-client
/ip dns static
/system clock
/tool mac-server
Device connected to ether 4 by wire got the IP address from main dhcp: 192.168.88.xxx, not the one from vlan10. Still no traffic is shown on interface vlan10.
Do you not see the issues of your config??
(1) How can you assign an IP address to an interface and especially ether2
when you assigned the associated dhcp server to the bridge??
(2) Ether2 seems to be where you want the vlan10 so I am assuming its a hybrid port ??
One can only conclude that ether2 connects to a device that is feeding the router both regular LAN traffic and vlan10 traffic and therefore the router is connecting to a smart switch or something that can have trunk ports at its end (be it switch, a capAC another mT router etc…)
Following that logic…
It should look like…
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
Thanks @anav fir answer but assigning address to ether2 works fine and I have no problems with it. On my eth2 I have connected switch (Cisco SRW2048) where all devices (including APs) are connected and all of them works fine - gets an IP, etc. Problem I have is that no devices connected to ether2 with vlanID = 10 can get and IP address from dhcp_pool2 (192.168.10.x)
