Can't Nat to Modem (Solved)
Hi guys,
I have a extrange problem here, this connection always work, and now stop working - give Syn Sent error.-
The LAN its in 10.1.41.0/24 and the modem its in 10.0.0.1 - From the internal network you can put 10.0.0.1 in the browser and works OK.-
From outside you can connect to the web interface of printers, webmin, routers, etc - But not to the modem.-
I use the same rules for all the devices working.-
Like you can see, don’t move packets into the Filter Rule.-
SOLVED
I make a mistake in the Mascarade Rule, put an Address list in the NAT, my mistake.-
